Oil & Fuel Braided fuel lines
   / Braided fuel lines #1
rdbigfarmboy
Collinwood, TN
MF, Same,Zetor
I have had a problem with Diesel starvation on my Tractor King 404. Changed filters. It would start and run a few minutes loose prime and quit. I called RK they said a common problem was the braided metal lines from primary pump to filter and back to distributor. I pulled the lines off the banjo fitting and replaced with rubber fuel ines and clamps. Runs good But I broke a bleed screw in the process and no must replace it. The braided metal cased lines are not correctly sealed and spin on the banjo fitting.
UNUSED WOLVERINE TQH-26-02C CLASS II 3 PT HITCH (A51248)
UNUSED WOLVERINE...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
2011 IC Corporation PB105 School Bus (A52377)
2011 IC...
UNUSED JCT HYD HD BACKHOE ARM (A51248)
UNUSED JCT HYD HD...
UNUSED ECHO CS-4010 CHAINSAW (A51247)
UNUSED ECHO...
