Backhoe Bradco vs Woods Backhoes
   / Bradco vs Woods Backhoes #1
Anonymous Poster
Epic Contributor
I have been looking at buying a backhoe for a little while. I am wondering what the difference is between a Woods and Bradco backhoe. I am also wondering which model Bradco would compare to the 6500 or 7500 Woods Backhoe??
Thanks,
Knowles
   / Bradco vs Woods Backhoes #2
The last 1 or 2 numbers on Bradco is the depth in feet like 3375=7.5ft.,509=9ft.ect.
The first # is the strength of unit, the higher the # the more HD.
On Woods the first #'s are the digging depth in feet,6500=6.5ft.,7500=7.5ft.,9000=9ft.
I had a Woods 7500 and traded a landscaper for a 9000.
The 65&7500 use a chain for swing (lite duty IMO) and the 9000 is built more HD.
Go here for more info on lots of equipment http://www.abcgroff.com/ic/indust.htm
   / Bradco vs Woods Backhoes #3
The 3375 would be the unit. Has a 4 point connection and subframe like the Kubota TLB's that stays with the tractor rather than the typical subframe on the Woods 7500 $5500 estimated.
   / Bradco vs Woods Backhoes #4
I have a Woods BH that just rocks (love that thing), but from what I have heard the Bradco is a bit more "stout". I think it is also more expensive. Probably depends on how often you'll use it and whether you're doing heavy duty digging.
   / Bradco vs Woods Backhoes #5
I have the 9000, it seems to have plenty of power even running at the lower 2300-2400 RPM range. It's running off the tractor hydraulics(8.3 gpm). The PTO version has a 9gpm pump. Lot more power than the Bobcat 325(?)track excavator they loaned me while getting the subframe installed.
My neighbor just had a Bradco 509 sitting in his driveway. He contracted some work. I did not compare them side by side but 509 looked more/less comparable. The specs were better on the 9000 vs the 509. Don't know that you could go wrong either way though.
I was thinking about the 7500 and am very happy that I went with the 9000. Much more hoe for 1k more.
   / Bradco vs Woods Backhoes #6
ABCGroff is a dealer, Attachment Technologies, Inc. is the builder of Bradco Hoes. I believe they are in Delhi, Iowa. I think I spelled "Delhi" right?
2009 FREIGHTLINER M2106 26FT BOX TRUCK (A58017)
2009 FREIGHTLINER...
2016 Ford Explorer AWD SUV (A56859)
2016 Ford Explorer...
2015 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A58017)
2015 FREIGHTLINER...
1000000 (A47477)
1000000 (A47477)
Hilti TE 2000-AVR Electric Jack Hammer (A55973)
Hilti TE 2000-AVR...
2017 RAM 5500 Bucket Truck - Cummins Diesel - Automatic - 4X4 - Terex TLM40 Boom (A55302)
2017 RAM 5500...
