Backhoe Bradco Backhoe for Ford
   / Bradco Backhoe for Ford #1
jgbanshee
PA
JD 310SE, 4300, 5300, 5210, 450 Crawler, CAT D3B, Ford 2N, 5000, 4000su, 3610, 345C, 340B, 1100
I have a Ford 345C tractor loader with a 26 GPM hydraulic pump to run the loader. I would like to carry that to the backhoe with a power beyond setup through the loader valve. My dealer tells me that the 26gpm flow is too much for a Bradco backhoe attachment. Is this true?
   / Bradco Backhoe for Ford #2
He maybe right, but you can put a flow restrictor in line with the supply pressure hose, and reduce the flow, and a wee-bit-o-pressure also. :D
Where can I find one of those? Will it reduce the flow and pressure to something reasonable to run the backhoe?
   / Bradco Backhoe for Ford #4
We have a old ford backhoe on a 1968 3000 ford but it is 11ft backhoe .The pump is a cesna i think but i dont know the gpm it's running.I would call bradco direct they have a good amount of knowlage on these set ups.The backhoe we have has pressure valve's on it you can adjust.
   / Bradco Backhoe for Ford #5
I'm not a hydraulic expert. But, I thought that the Power Beyond send ALL of the fluid that wasn't used to the next implement in line. If that is true, then you can't just plop in a restriction.
But, you can put an adjustable flow divider from the power beyond and split the flow between the backhoe and the return to tank from the loader.
Surplus Center - Hydraulic Equipment Electric Motors has them and pretty low $. Fer instance, Item 9-2597 would bleed off 7 1/2 gal to the tank and keep 19.5 gal going to the hoe. Might be about right? it's about $45.
jb
PALLET OF DRAINS / DRAIN GATES (A51244)
PALLET OF DRAINS /...
2015 MAC FLATBED 48FT TRAILER (A52141)
2015 MAC FLATBED...
2007 HYDRO-AX 764 MULCHING MACHINE (A51242)
2007 HYDRO-AX 764...
2018 FORD F-550XL SERVICE TRUCK (A51406)
2018 FORD F-550XL...
THE ROOTSTER STUMP & ROOT PICKER (A51243)
THE ROOTSTER STUMP...
2011 Ford F-150 Pickup Truck (A50323)
2011 Ford F-150...
