bradco 609 "good deal"
   / bradco 609 "good deal" #1
SHIFTY
Connecticut
bradco 609 \"good deal\"
Any one interested in a clean bradco 609 4 point mounted backhoe?it will dig 9'10",its a hell of alot of hoe fothe money,new it goes for 10500.Ill let this go for 5800.00 Its in very good condition with a 16 or 18 inch bucket
   / bradco 609 "good deal" #2
Re: bradco 609 \"good deal\"
Will the 609 hook up with a case 1845c uniloader?,What is the weight of your backhoe? Thanks Jon
   / bradco 609 "good deal" #3
Bradco 609 with 12" bucket wieghs 1702 lbs. 45 more lbs for 24" bucket. Can call Bradco, 800-922-2130, to see if compatible with 1845C uniloader. I have a 611 hoe that was mounted on a case skidsteer when I bought it.
   / bradco 609 "good deal" #4
SHIFTY, Where are you located?? Will the hoe fit on my 3710 GST? I have been looking for a 509.
Thanks
Jim
   / bradco 609 "good deal" #5
Jim1764
Shifty's mounting plates will fit right on your 3710 GST. I have bradco 611 mounted on a 3710Gst. The mounting plates are the same for Gst and Hst. I bought new mounting plates for my tractor and for the hoe when I bought the hoe. Cost for just mounting plates is over $1000.
   / bradco 609 "good deal" #6
Re: bradco 609
Thanks radman, SHIFTY noted that the hoe was on a John Deere 4500, will the mounting plate on the hoe fit on to the Kubota tractor mounting plate? I know I need to get a mounting kit for the tractor but I'm unsure if the plate on the hoe, ment for a John Deere, will mate with the Kubota mounting plate on the tractor.
Thanks,
Jim
   / bradco 609 "good deal" #7
Re: bradco 609
How does the 611 compare to a mini-excavator?
I have used the middle of the line bush hog (752) and it worked ok but would like better performance. The bradco specs on the bucket are about three times the breakout force of the bush hog.
The Bradco 611 would still not be a Case 580, but a good hoe?
Gary
   / bradco 609 "good deal" #8
Re: bradco 609
Dont know for certain if the mounting plates on the hoe for a JD 4500 would be the same as for a Kubota. I really doubt if it would be the same. Bradco makes different tractor and hoe mounting plates for each make and their different models. Bradco will immediately tell you and will even fax a printout of the required mounting plates, power beyond kit, or pto kit if you ask.
   / bradco 609 "good deal" #9
Brand New Bradco 609 backhoe w/ mountings and hydraulic kit for a Kubota L3710, $7800.00 for Kubota Orange add $175.00
   / bradco 609 "good deal" #10
Wow, that's a great price! I always thought Bradcos were mega-bucks! Can my L3010 handle a 609?
Pete
2004 Freightliner FL112 Cab & Chassis (A47384)
2004 Freightliner...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A51691)
2025 Kivel 48in...
Ryno Worx Sealant Applicator and sealant pots (A52384)
Ryno Worx Sealant...
Engel 20' Boat (A50121)
Engel 20' Boat...
78in Screening Bucket Skid Steer Attachment (A51691)
78in Screening...
