Bradco 509 owners question on correct PTO pump
   / Bradco 509 owners question on correct PTO pump #1
Boss 302
Platinum Member
Va.
Kioti RX6010PS Mahindra 3510 Sold (Gonna miss that ole girl)
I am looking at the Princo HC PTO 1A and HC PTO 2A pumps and would like to know what you guys think would be the better fit for the 509. The 1A is advertised at about 21 GPM at 540 RPM and the 2A is approx. 11 GPM at 540 RPM. I am leaning towards the 2A, what do you guys think?
   / Bradco 509 owners question on correct PTO pump #2
I just put a 509 on a Mahindra 3510. the pump is rated at 7.87 GPM and it operates the 509 great at 540 RPM (2000 RPM on Tach) My BH operates off the tractor hydraulics
Hope this info helps
   / Bradco 509 owners question on correct PTO pump #4
Are you setting up a completely separate hydraulic system? If so, what size tank are you going to have room for? The tank needs to be sized to the pump and load.
   / Bradco 509 owners question on correct PTO pump #5
I've got a 511 BH...it needs at least 9 g/m to operate well...I have a 14 g/m unit on it...runs it great even at 1200 tach rpm...I'd say get the 21 g/m unit (if it fits in there) and go about your business...BobG in VA
Unused 2025 CFG QK18R Mini Excavator (A49461)
Unused 2025 CFG...
WATER CONTAINMENT/TRASH CONTAINMENT SKID (A50854)
WATER...
2020 JLG 1732 16,755lb 4x4 High-Capacity Rough Terrain Telehandler (A49461)
2020 JLG 1732...
Ford Super Duty 8ft. Truck Bed (A49346)
Ford Super Duty...
2003 FONTAINE TL50-NGB TRI AXLE RGN TRAILER (A51222)
2003 FONTAINE...
2017 Mack GU713 Granite Tri-Axle Dump Truck (A49461)
2017 Mack GU713...
