Brackets for ROPS
   / Brackets for ROPS #1
wakeshredder
Parkville, MO
Massey Ferguson GC1720
Hey, does anyone know of a bracket for the GC series (or any similar sized) ROPS that is made of rubber or plastic? I want to find something to put attachments on the ROPS like lights or tool holders. I do not wish to drill into the ROPS or use metal as it may encourage rust. That and it could chip the paint encouraging more rust and compromising the ROPS. Thinking something that clamps on... Thoughts? Links? Thank you!
   / Brackets for ROPS #3
You can sleeve a U hook bracket with rubber, nylon or vinyl hose to prevent wear. Just know that they potentially trap moisture behind them and promote what you're trying to prevent in the first place
   / Brackets for ROPS #5
When I first got my tractor, I used a u-bolt with steel backer plate. Those didn't seem to scratch up my paint. I used a wooden carpentry shim between the metal surfaces because I was worried about scratches, too.
I recently purchased the aluminum ROPS Clamps from Ken's BOH. Those are my mainstay, right now.
Long ago, I 3D printed some clamps just to see if I could.
Interestingly enough, my prints were somewhat similar in design to the aluminum version that I purchased from Ken-that being a split rectangular shape and through bolts to draw them in.
Biggest drawback was that they had to be a good bit larger than I liked in order to be strong enough for the job. My plastic version have always been modified to better suit my janky light mount hardware and I added recesses for captive bolts. I've since gotten rid of those lights and with them the need to use the plastic clamps.
I plan to revisit the idea of printing them but haven't the needs now that I have the aluminum clamps.
Note-If you decide to try and go the u-bolt route, if you only happen to come across 4 inch wide bolts, they work fine when clamped across the ROPS diagonally.
   / Brackets for ROPS #6
In the lumber section of Big Box stores, usually near the PT lumber, you'll find structural steel brackets in various shapes for tying joists, rafters, beams and posts together as well as mending plates and other materials. In that area are longer straight straps about an inch or so wide in different lengths. Those are thin enough to easily bend into whatever shape(s) you want and strong enough to hold anything you'd want to mount to these bars. They're steel so they're prone to rust if left exposed, but can easily be painted or coated. A piece of rubber or weatherstrip under will protect the painted surfaces.
The stuff is inexpensive enough that you could make several for $20 or less including SS or galvanized bolts and nuts.
This one is 25" - 16 Gauge for $4.00, but many in 18 Gauge are priced lower.
If you were careful enough, you might even be able to weld tabs or ears onto them to mount accessories at different angles.
Lowes Item # 140729 Model # KRPS28-TZ
   / Brackets for ROPS #7
I had a local metal shop cut me some pieces of mild steel strap (1/8" x 2") and welded them together to make a clamp affair to mount the ROPS lights on the inside. Easy to do and they work well. I used existing "mickey mouse" light bolt holes, but they could be placed almost anywhere with some cushioning grip surfaces installed. Primed & painted afterward.
   / Brackets for ROPS #8
What rust?
   / Brackets for ROPS #9
   / Brackets for ROPS #10
So, Ken -- they'll work on our mini-tractors' 1-3/4" x 3" ROPS?
Crosley 10ft. Hydraulic T/A Dump Trailer (A50322)
Crosley 10ft...
(2) SODA FLO CONTAINERS (A51244)
(2) SODA FLO...
Massey Ferguson 65 Loader Tractor (A50514)
Massey Ferguson 65...
2000 JOHN DEERE 310SE BACKHOE (A51242)
2000 JOHN DEERE...
2006 John Deere HPX Gator 4x4 Utility Cart (A50324)
2006 John Deere...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
