Boyou 300 idle issue
   / Boyou 300 idle issue #1
Smoody
Platinum Member
South Carolina
YM226D
I have a Kawasaki Boyou 300 2 WD, it is a 1996 model bought new. past couple years I have noticed it will stall out and not idle properly, It seem to eventually choke off if sitting idle for more then a few minutes especially once it heats up. Bad Carberutor?? other then that is runs fine while moving, just idling is the issue.
   / Boyou 300 idle issue #3
I have a bayou 220, and it seems to like a really new plug. I think it might be running slightly rich, which might fowl them over time. Every year or so I pop in a new plug and it really smooths things out.
When I just used it for play, it seemed to be tunned right, but pulling sprayers and small trailers and other things, I do not think it gets to rev enough. Anyway I try and give it an "Italian tune up" every once in a while, but I really do not know if it helps clean things up.
Good luck, Dave
   / Boyou 300 idle issue #4
I have an 89' 300 Bayou 4wd. Mine ran like crap and finally stoped all together. I took the carb a part and found lots of "crap" in the slidearea from the slide moving in the diaphram. It was jamming it up not allowing it to move. It might be wise to take it apart and give a look. I cleaned it all out and put a new needle valve in and it's run like mint for the last year.
2018 FORREST RIVER CRUISE LITE CAMPER (A52472)
2018 FORREST RIVER...
TAKEUCHI TL150 SKID STEER (A51242)
TAKEUCHI TL150...
2006 Volvo VNM Truck, VIN # 4V4M19GF26N396168 (A51572)
2006 Volvo VNM...
2012 LEEBOY 8515B APHALT PAVER (A51406)
2012 LEEBOY 8515B...
2000 John Deere 1860, 30ft Wide, Gandy Box, Wing Fold, 7.5in Spacing (A52748)
2000 John Deere...
