Boxblade weights and receiver hitch
   / Boxblade weights and receiver hitch #1
JustBob
Mobile, Alabama
2005 New Holland TT55
Well... thanks to these forums, I had to do something about the weights on my boxblade. (a lot of good ideas on this forum!) I had been placing them on the braces the brackets are now welded to, but they would come loose ever so often. To permanently fix the problem, I cut the piece the weights mount to off of the bumper of my tractor (cant mount the bumper because of loader).
Then I cut that in half to make 2, one for each side...
Installed and properly bolted the weights in place, they aint going anywhere now!
Thanks to the forums, I decided to add a receiver hitch to my boxblade, so I added that while i was finishing up the weight brackets.
Paint is on the to do list, when I get a break in the rain...
   / Boxblade weights and receiver hitch #3
Looks good, but it seems that the receiver should have braces on the back side to prevent side/up-down loads from bending it out of square. Depends on what you're going to tow with it.
You are right, I did not have time to add the gusset at the bottom, I think it will hold until I weld the gusset in as the piece it is welded to is 1/4". It is for moving trailers only, not for towing or transport, I have a trailer ball for my drawbar for when I tow with the tractor.
2011 DOOSAN G25KW GENERATOR (A58214)
2011 DOOSAN G25KW...
2017 JOHN DEERE 323E SKID STEER (A60429)
2017 JOHN DEERE...
2010 Massey Ferguson 2625 (A60462)
2010 Massey...
2019 CATERPILLAR D6 HIGH TRACK CRAWLER DOZER (A60429)
2019 CATERPILLAR...
(1) 48"X8' ADS DRAINAGE PIPE (A60432)
(1) 48"X8' ADS...
2004 CATERPILLAR D5N XL HIGH TRACK CRAWLER DOZER (A60429)
2004 CATERPILLAR...
