Box Scraper Box scraper for driveway maintenance?
   / Box scraper for driveway maintenance? #21
studded tires, we have them on all of our vehicles.
It's also about maintaining a level safety for others who use the road. There's two other homes which share my private road plus I'll likely be keeping clear another private road with approx 15 homes on it. Sad part is it would be probably be cheaper if everyone outfitted themselves with studded tires than to purchase a spreader and the necessary sand. Still though the road needs to be safe for those providing services and pedestrian activity.
   / Box scraper for driveway maintenance? #22
Mine is over a half a mile up the side of a mountain. I gave up and paved the gol darned thing........
   / Box scraper for driveway maintenance? #23
I hate to bring this up but, consider the liabilty issues of doing this type of work, make sure you are not at risk of being held responsible for other peoples accidents and loss of control while driving these roads.
Steve
   / Box scraper for driveway maintenance? #24
Steve
Appreciate the heads-up but this area of concern has been addressed. Definitely not an area to be overlooked.
   / Box scraper for driveway maintenance? #25
I have a B7800 also, I maintain the Comunity road, 1/4-1/2 mile 1"minus crush (10 yrs old) is now mostly crush. I have a LP1572 Rear Tilting and Angling blade (6'). It's worked great for everything including ditching, grading and snow removal. I gave away my Box Blade as it just can't work that much road fast enough for me... er the neighbors (before they drive over it ... while I'm still working on it... arg)
Make sure to "Crown" your road if you get any rain, as there is nothing worse for a road bed than standing water. Well maybe... channeling of run off down the middle..... GRRR.
   / Box scraper for driveway maintenance? #26
My limited experience:
I have a box blade, for several years now. Only had a straight blade for ~1 year.
Both should be as heavy as they can be, as the 3 point has no down pressure to force the cutting action. Sometimes folks have had to buy different top links to get enough angle for the blade to work well (bite angle).
The two things I think my straight blade does better: it has a double jointed arm on it, so I can swing it out to a ditch, or near a fence, and keep my tractor out where I can maneuver it (or where is is safer). Also, it moves more material over (as opposed to filling in holes). This is really nice on long runs. My box blade is nicer for more specific movement of volume and filling in holes. The blade 'chatters' much easier than the box blade.
Scarifiers do a similar job as the various 'land plains' and 'conditioners' do: they bring the small aggregate back up, but probably don't do it as good as the conditioner equipment. You can overwork the soil and end up with only the larger gravel on top -- difficult at that point to get it butter smooth. That's the same affect as what happens after a road gets used and the aggregate 'settles in'.
At some point you may get the 'whoop-de whoops' in your drive. I am sure there is some method of measuring the distance of the blade to the rear wheels and dividing by the wheelbase and knowing the frequency (distance between) of them, but this is where the land plains and conditioners win out. I have been considering adding a gage wheel some distance behind my blade and seeing what affect it has. Maybe just adding some long chinks of angle iron along the sides would be good enough.
You do realize this will lead to further 'accessorizing' activity? Things like 'top and tilt'. I am not afraid to say -- their is no known cure for this. Resistance is futile, you will be implemented.
There are more specific tools that will do a better job at individual tasks, but the box blade is really difficult to beat as the first of these tools (or, if I can only own one tool). I would get one with a floating rear blade -- when the front is tilted way up, this makes a great smoothing (or final) pass.
Manual scarifiers work great (just tilt the box). Helps justify the top and tilt you wanted anyhow (and that can be used on all your implements as well as for hooking/unhooking implements).
   / Box scraper for driveway maintenance? #28
I use a Frontier SP1060 5' soil pulverizer to rip up and level and then go back over it later with a Frontier BB2060 5' box blade with the rippers up. I find the rippers on the box blade are too coarse and leave ruts vs the soil pulverizer tearing it all up. The last time I used my rear blade was clearing snow last winter. I only have abt 1000' of yard to do.
MINI EXCAVATOR BUCKET 32 (A55745)
MINI EXCAVATOR...
2019 Bobcat 3400 4x4 Utility Cart (A51691)
2019 Bobcat 3400...
2015 Volvo VNL 64T (A55315)
2015 Volvo VNL 64T...
2014 CS&P  BLENDER (A55745)
2014 CS&P BLENDER...
2018 UTILITY VS2RA 53FT REEFER TRAILER (A56129)
2018 UTILITY VS2RA...
2008 STEPHENS CRUDE TRAILER (A55745)
2008 STEPHENS...
