box scraper dollie
   / box scraper dollie #1
DIRTCUTTER
New Mexico
CK30 HST
If you dont have a dollie for your box scraper think about building one, for me it was a whole lot easier to move the box scraper into place to reattach. Next project since this worked so well is a backhoe dollie.
   / box scraper dollie #3
there was a post a while back about buying the 4 wheeled 'furniture' (not hand truck) dollie from Harbor Freight/Nothern Tool for the same use, but they did not stand up to the long term weight. What design did you use..
Brian
texasjohn said:
pictures? weight capacity of each wheel?
I have a 5ft box. What I did was , made a 24in x 54in frame using 2x4. I attached 2x6x24in strips across the bottom an attach 2in swivel casters at each corner. I covered the top with 1/2in plywood. As far as weight capacity of each wheel I have no idea, it just something I have laying around my shop.I will posted photos???
   / box scraper dollie #5
I looked up the weights of several box blades..267lb, 640lb, 498 lb, 510lb. .. so, let's assume that you need to handle 650 lbs total. My experience is that setting stuff down is not always exactly flat or centered. Thus, I'd say that the entire weight needs to be withstood by two wheels.
If this is the case, then each wheel must be capable, minimum, of holding and operating at 325 lbs without breaking. An engineering safety margin would take that to maybe 500 lbs each. Subtract/add the weight of the platform somewhere along the way. I'm hopeful your 2 inch casters will stand up to your needs. Typically, 2 inch casters do not have this kind of weight capacity.
Your backhoe dolly will need some really tough casters since I bet it weighs more.
I've been thinking of doing something like an equipment dolly, but haven't yet located, for a price I want to pay, 4 wheels that meet these specs... but, I'm watching the scrap metal place...you never know what will show up thre.
Tex, take a look at Western spurs cowboy gear shipped quick. You will find plans
   / box scraper dollie #10
Great site with plans for dolly, boom sprayer and foam marker, other good projects with great photos and instructions...Thanks:)
2015 FREIGHTLINER M2 DAY CAB (A52141)
2015 FREIGHTLINER...
2018 Nissan Titan Crew Cab Pickup Truck (A50323)
2018 Nissan Titan...
Tarter 4' 3 pt Box Blade (A50515)
Tarter 4' 3 pt Box...
2009 Heartland Camper (A50514)
2009 Heartland...
Case SV 340 Skid Steer Loader (A52349)
Case SV 340 Skid...
2020 New Holland 105 Workmaster MFWD Compact Tractor with 632TL Front Loader - Poultry Special (A52748)
2020 New Holland...
