Box blade
   / Box blade #11
I use my box blade as well, for snow removal. At times I’ll use my rear blade, but usually just use whatever is on the back when the snow flies.
The box blade works surprisingly well.
   / Box blade #12
This is my 4' box blade attached with the rippers at the rear, moving sand rock:
And moving gravel:
Last night I attached it with rippers forward to move some red clay:
It was too dark for pictures when I finished. Will get some today.
   / Box blade #13
There was a large pile of dirt in the foreground like the one in the background. Most of it had been moved with a bucket on other machines:
Used the box blade last night to push it over into a small loose pile that will be easy to pick up.
   / Box blade
I'm glad I can still plow snow ,my plow truck I'm putting all new rotors and breaks front and back.
   / Box blade #15
I switch between using my GC1710 with a box blade and FEL and my Cub Cadet walk behind blower for snow management. The box blade does a better job of not pulling up stone on my gravel driveway than the blower as it floats on the rear blade as I drag. Even with the gauges on my snowblower they are narrow and sink into the stone causing my blower to start scooping up and spitting out some of my gravel.
2006 WARREN 30' DUMP TRAILER (A54756)
2006 WARREN 30'...
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A56435)
2023 New Holland...
1605 (A57192)
1605 (A57192)
2008 Ford Taurus SEL Sedan (A55973)
2008 Ford Taurus...
Giyi Pallet Forks (A53314)
Giyi Pallet Forks...
2011 JACK COUNTY 130BBL VAC TRAILER (A55745)
2011 JACK COUNTY...
