Grading box blade
/ box blade #1
mechanic
missouri
What's your experience with using a box blade to cut weeds off at ground level? Does it dig up a lot of dirt? I think by just using the blade without the teeth it should work pretty good. Any thoughts?
/ box blade #2
mechanic, I have done a great deal of this very thing, mainly because I have a 4 acre section by my house that I 'clear cut' two years ago and am not trying to clean it up. I pulled the box blade at idle speed along the perimeter in order to ''blaze a trail'' for breaking with the disc harrow.
The box blade, without the scarcifiers, and engaged at slightly below grade removed all the vegestation and small saplings and would occassionally catch a stump. When that happened, I just backed up and found a route around the stump. My end goal is to cut a fire lane and then burn the whole thing off.
The box blade working exceptionally well for that purpose.
/ box blade #3
Like Herd said , it works well on fairlly level ground . It just takes getting the right adjustment on the upper link so it wont dig in to deep .
I used mine for this very reason last night & after I got it set right it worked quite well . Just made a couple of big piles of weeds that I scraped off & hauled them to the burn pile . :D . Bob
/ box blade #4
Once you get a hydraulic toplink you'll see the many,many things you can do with a boxblade !!
/ box blade #6
Get your tractor wheels and box blade on a level concrete or ashphalt, and level the blade side to side and then use the top link, as previously stated, to get the front blade a little lower than than the rear blade. Once you get into the field, you can fine tune the top link to get the cut action you want. Hope this helps.
1952 John Deere A Tractor (A66408)
1952 John Deere A...
3pt Hitch Receiver (A62679)
3pt Hitch Receiver...
GYRO TRAC GT-25 FORESTRY MULCHER (A65053)
GYRO TRAC GT-25...
2022 EZ-GO ELITE...
2023 Schulte FX-318 Flex-wing Rotary Mower (A66285)
2023 Schulte...
INOP/NON-RUNING Genie GS3232 Scissor Lift (A65579)
INOP/NON-RUNING...
