Box Scraper Box Blade use question..
   / Box Blade use question.. #21
Rick, There was some advice given on how to angle the box for deeper or shallower cutting, and others took exception to it. I wonder if the difference has to do with whether the rear blade is hinged or not. Seems like that might affect the action of the blade.
Also, Rollover Box Blades may adjust somewhat differently from conventional Box Blades.
Mine is a Rollover. I have never used a conventional Box Blade.
Germane LINK:
http://www.tractorbynet.com/forums/attachments/43480-rollover-box-scraper-floating-tailgate.html
   / Box Blade use question.. #22
Also, Rollover Box Blades may adjust somewhat differently from conventional Box Blades. Mine is a Rollover.
Germane LINK:
No doubt about that. As you know, with a ROBB you pretty much set the top link and you are done. With a std type BB, the top link needs to be constantly adjusted to allow for the type of cut that you want with either the front or rear blade. Having the hinged rear blade allows for a deeper cut when using the front blade.
Jim, mine is a fix blade unless I tilt it with the 3pt ;) you think having the boxblade on there for ballast while using the FEL would be enough? It weighs more than tire weights or fluid ballast would I think
Jeff, that BB is awesome.. wish I had gone the extra and found something like that before I got the standard one
   / Box Blade use question.. #25
As having just acquired a used standard fixed rear blade bb and weather/ground conditions haven't been good for use yet, I also greatly appreciate this use tutorial from everyone. I've also gone to YouTube and entered Box Blade in the search box and several good videos of it's use come up, especially one by everything attachments. The OP might find this useful also - as they say - a picture is worth a thousand words. KW
   / Box Blade use question.. #26
   / Box Blade use question.. #27
If you're ripping hard material and your tractor comes to a stop, you can always remove some of the scarifier shanks. Shorter top link does dig more aggressively, just a bulldozer does. If the top link is adjusted too short, the box blade will be riding on the front corners of the sides and not dig at all. This is good for light spreading of material but will wear the front corners of the sides out. Some box blades have extra thickness or replaceable shoes on the corners just for this purpose.
   / Box Blade use question.. #28
Do you think having the boxblade on there for ballast while using the FEL would be enough?
Yes. The first 700 pounds you pick up with the FEL will be balanced by 700 pounds of Box Blade ballast = FEL load "0".
Counterbalance ballast BEHIND the rear axle is at least as important for relieving strain on the front axle. Many tractors roll when operator has something heavy in the bucket, with no counterbalance, then drops a front wheel in a hole or rut…….and over the tractor goes, often with the result of a bent front axle. The tractor and FEL load are much more stable with counterbalance.
Filled tires nor wheel weights, which are not behind the rear axle, do almost nothing to relieve front axle stress.
   / Box Blade use question.. #29
jeff9366 really got it right about the importance of a heavy weight carried on the 3PH when doing loader work. Filled or weighted rear tires will at least help to keep the tractor on the ground when picking up something heavy with the loader, but the front wheels and axles become the fulcrum, and are subjected heavy loading. With a heavy weight on the 3PH the rear wheels and axle become the fulcrum, and they can handle it much better.
One thing to be aware of, and has been mentioned in these forums, is if the rear wheels are not weighted and you have a heavy load in the loader with a heavy attachment on the back, and you lower the 3PH to the ground, the rear of the tractor can go flying up in the air like a seesaw, since you've unweighted the rear. I've never had this happen because I do both. My rear tires are filled and I always have something on the 3PH when doing loader work.
Those rollover blades look interesting, but I'm guessing they're a lot more expensive...
   / Box Blade use question.. #30
A lot more expensive than what? They are about 1/2 the cost of an industrial BB and maybe $500 more than a std type BB of the same weight.
When it comes to new implements, you usually get what you pay for. ;)
(100) UNUSED FUTURE 3'X12' CORRUGATED METAL SHEETS (A58376)
(100) UNUSED...
2022 John Deere 1025R (A53317)
2022 John Deere...
2022 ALLMAND LIGHT TOWER(INOPERABLE) (A58216)
2022 ALLMAND LIGHT...
2011 Ford F-750 Etnyre 2,000 Gallon Asphalt Distributor Truck (A56858)
2011 Ford F-750...
2008 FREIGHTLINER COLUMBIA ROAD TRACTOR (A58375)
2008 FREIGHTLINER...
LOT: (40 approx. ) Chain Link Fence Panels (A59076)
LOT: (40 approx. )...
