Grading Box blade tricks on a BX
   / Box blade tricks on a BX #1
chucko
Veteran Member
Polk Co , Fl
bx1800
Ok I have used box blades on full size tractors and never had too much problem setting the at the correct height to level a drive or whatever but I and sure having problems with my 42” land pride behind my bx1800 and was hoping that you guys had some hints / tricks that could help me.
Seems if I set it all the way down that raise the 3 pt to were it just touches the ground and start to move the tractor because of the short wheel base of the tractor the blade will dig deep as soon as the tractor moves or will come right up off the ground as the from wheels go in even the smallest of dips. Would I be better to let it float on the back blade and adjust the top link so the back blade hits first and leaves the front blade ½ inch or so off the ground. Or do I have to move very slow and just keep denking up and down on the 3 pt. They problem I have always found with moving slow is traction
   / Box blade tricks on a BX #2
Had same problem with 42 inch box on my bx2200. Tried numerous 'tricks' as suggested on this forum. Never have learned the 'art' of boxing yet.
So,
Here's my easy 3 step solution:
Step 1: Install box on 3ph.
Step 2: Turn tractor around, use box as counter weight, and do grading work with FEL.
Step 3: But box blade back where you got it when finished. /forums/images/graemlins/grin.gif
   / Box blade tricks on a BX #3
Hey that's good.
I also have better results using the bucket and not the box blade......... And I do use the box blade for a counterweight.
Ron
Well I don't have a loader so I need to learn the blade for now......guess I will go find a sandy field and see how much damage I can do
   / Box blade tricks on a BX #5
</font><font color="blue" class="small">( Would I be better to let it float on the back blade and adjust the top link so the back blade hits first and leaves the front blade ½ inch or so off the ground. )</font>
Letting it float is what I consider the best method. Of course, sometimes that requires rather frequent changes in the length of the top link, which is the main reason I liked the hydraulic top 'n tilt so much.
   / Box blade tricks on a BX #6
<font color="blue"> Seems if I set it all the way down that raise the 3 pt to were it just touches the ground and start to move the tractor because of the short wheel base of the tractor the blade will dig deep as soon as the tractor moves or will come right up off the ground as the from wheels go in even the smallest of dips. </font>
chucko,
At first it did not register...in my mind, but now I see what you are asking. I think I have been doing what Bird has done, so I may be repeating what he said, but here goes anyway.
Also, I am a self-taught box blade user...thanks to all the advice I have read here at tbn. This works for me, for what that is worth... /forums/images/graemlins/smile.gif
If the box blade digs in deep, my guess is that it is angled too far forward. I would lenghten the top link to make it dig in less if it were me.
I generally lower the 3ph the whole way and let the box blade do its own thing as I pull it. The linkage then moves as the tractor front moves up and down, but the tractor does not lift the box, and simply pulls it.
The top link sets the angle of the box. If the box is too aggressive, when going forward, I lenghten the top link. If it is not aggressive enough, I shorten the top link. It takes a little practice to get it right. Guess why a top & tilt is on my wish list?
I don't think I have ever had a set up that worked in both directions. Extra weight in the form of concrete blocks on top of the box blade also seems to help for some reason. Probably because the weight makes the box cut well at a lesser cutting blade angle...
Now I have not used the box on my BX2200, only on my B2910. I don't know if there would be any difference with the smaller tractor or not.
Hope we hear more from other BX boxblade users...
   / Box blade tricks on a BX #7
I have the same problem on my bx2200 with a 48inch box. I agree that changing the top link angle makes a difference and as you say that is a big help. I was wondering if the hydaulic top link wold help make that easier so it sounds like from your experience it would be worht looking into.
I think the problem is made worse because the 3ph is not "positional" On full size tractors I have used with positional 3ph it is much easier to move the implement to compensate when thefront wheels go over bumps or dips or if the box starts to dig in too much.
I also have used boxes that have a live or free swinging rear blade/gate. That seems to improve the ability to smooth things out going forwand since it sort of acts like a back blade.
Like someone else suggested I often use the box to drag a bunch of material to the approximate place then do final smoothing with the fel.
ok I think I got it.....3 pt all the way down and
assuming I am pulling and not pushing
a. front of blade up (long top link) to dig very little
b front of blade down (short top link) to dig deep
and the sweep spot is somewere in between the two
thanks guy
Wow adjusting the blade the correct way sure helps....Thanks guys...
Now I have to firgue out how to get my 3pt to life the blade higher so when I have the top link adjust out that they back of the blade can come up more than 3 inches
   / Box blade tricks on a BX #10
Hey Chucko, sounds like you're on the right track. I too have struggled (and cursed) adjusting rear implements on the similar sized MF GC2300. I think you/we are experiencing the "limited" part of the "limited Category I capability" that's used to describe tractors of this size.
Personally, I think this is a pretty big deal. I remember asking the dealers specifically about what that meant, and never really did get a good answer. I think maybe because the dealers sell 'em, but don't really use 'em, they don't fully understand the limitation. I've lamented a bit that I didn't fully comprehend what a pain in the butt lack of position control can be (my own fault), but I think that, combined with limited lift / height on rear implements is really the crux of "limited Class I".
For future buyers, this is really something to consider and discuss with users and dealers, in my opinion. Good luck with your project Chucko. Keep us posted...inquiring minds want to know!
2005 INTERNATIONAL 9200I (A45046)
2005 INTERNATIONAL...
Scag Tiger Cat (A44502)
Scag Tiger Cat...
PT 1000 Gal Supply Tank (A44501)
PT 1000 Gal Supply...
2006 CHEVROLET SILVERADO PICKUP TRUCK (A43004)
2006 CHEVROLET...
30 AMP Safety Switch (A44391)
30 AMP Safety...
TMG-PT2020A 20ft X 20ft Outdoor Party Tent (A42745)
TMG-PT2020A 20ft X...
