Box blade size
   / Box blade size #1
dav
I am thinking of getting a box blade for a MF 1010, 16hp, 4wd, and am not sure what size to get. I want to use it to do some leveling and to loosen rocks for later removal with a rock rake.My tractor is about 4 feet wide. Will the blade do what I need it to? Will my tractor be able to pull it? Thanks for any feedback.
   / Box blade size #2
Just be sure the box blade is as wide (preferably slightly wider) than the tractor. I used a 4' blade behind my B7100 (16hp), but traded up to a 5' one for the B2710.
Bird
   / Box blade size #3
dav,
You wrote " box blade" but what model?
I know of 2 models and there could be more.
There a roll over box blade which weights about 550 lbs,and the box blades which weight about 250 lbs.
Bush Hog has both models in 48' & 60' also Bush Hog states box blade needs at least 15hp for the 48"
I have 16hp and Bush Hog 60" box blade and my 3 point hitch unit handles it well.
dav,if you get a chance check out the York Company at www.yorkmodern.com /w3tcompact/icons/wink.gif /w3tcompact/icons/wink.gif
The model RI to me is the best of both worlds,but the prices will [shock] you!! I purchase the RI model this spring and now my box blade sets idle.
Some tractor operators like to purchase by the wheel base and some don't thats if they have the horse power.
I perfer the next size up compare to my wheel base.
Maybe your locate dealer has some literature.
Take care and have a good day.
Thomas..NH
   / Box blade size #4
dav, I am pretty sure most any box "scraper or blade" will work within the width limits of your tractor. As Mr Bird mentioned, get one a little wider then the tractors wheelbase. If you have a loader, get as heavy of one as your are able to afford. It not only helps as a counter weight, but can do a better job helping to keep the cutting edge on the ground. Rat...
   / Box blade size #5
TufLine makes some good box blades. Check their website http://www.monroetufline.com for info on box blades and other equipment. They do not sell retail but you can email them for information about their equipment and dealers in your area.
   / Box blade size #6
Bird,
You forgot to tell him why.
If the boxblade is not as wide as the tractor and you need to scrape up against a house or fence......oops! It is embarrasing when the tractor tire removes the window trim. /w3tcompact/icons/laugh.gif
   / Box blade size
Thanks alot fellas I think I will go with a 5'. The window trim comment convinced me.
   / Box blade size #8
I have a KingKutter XB 48'' that I pull behind a 23 horse 2210 JohnDeere. I bet it would work for your tractor. It has 4 easy to ajust teeth that have three settings. Ive only used the max up and max down settings but it works great. It might work better for your tractor rather than a 5'.
   / Box blade size #9
You do realize this thread is nine years old:)
   / Box blade size #10
make that 11 years old and has came in useful to me :thumbsup:
12 Ft Enclosed Trailer (A50324)
12 Ft Enclosed...
2007 STERLING TRUCK ASPHALT DISTRIBUTOR (A50854)
2007 STERLING...
TEST BID LOT (A50774)
2017 Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
2017 Bad Boy...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51222)
2016 FREIGHTLINER...
New Power Line 500 Metal 3pt. Spin Spreader (A50774)
New Power Line 500...
