Dirt Moving Box Blade Scraper for SC 2400?
   / Box Blade Scraper for SC 2400? #1
Mike Buckley
Cub Cadet Sc 2400
Any recommendations for a box blade/scaper for my SC2400? I have a long hardpacked dirt driveway with some rocks and lots of puddle issues. I have a tow behind grader DR grader, but the scraper tines aren't deep enough to do the job. Thanks for any input.
   / Box Blade Scraper for SC 2400? #2
I have a Chinese made box blade with 3 tines for my Yanmar EA2400 (Aus equivalent to SC2400). It weighs about 240 lbs and will rip up to 8 inches. It works well enough, but does need weights on it to work in harder ground - and so would recommend a heavier unit. Need to bear in mind that your tractor is very light and so if you meet resistance you will loose wheel traction even in 4 wheel drive. I find that I get more traction when driving in circles rather than in a straight line.
   / Box Blade Scraper for SC 2400? #3
4' would be the right size scraper, and sounds like thats what you would need.....many units out there, from reasonable to very $$$. If you buy used, check out the welds and scraping blades. Get one with a front and rear (push/pull) blades. There's a great how-to-use-your-box blade thread in the attachment section.
   / Box Blade Scraper for SC 2400? #4
I used to have a sc2400.I bought a 4' one from tractor supply and it has worked great. My drive is only about 300' but I have to do it often. If I filled the box up it would stop me but I got used to using it. I now have a sx3100 and can pull the box full if its not real heavy gravel..
4' sounds like the best bet.Thanks. I'd appreciate any brand recommendations.
2016 Fiat 500X AWD Hatchback (A56859)
2016 Fiat 500X AWD...
2015 Freightliner M2 106 Terex Hi-Ranger TL55 55ft. Insulated Material Handling Bucket Truck (A55973)
2015 Freightliner...
(2) METAL WELDING STANDS (A58374)
(2) METAL WELDING...
SAKAI SV544D SMOOTH DRUM ROLLER (A52709)
SAKAI SV544D...
Adams 16T Tender Body (A56436)
Adams 16T Tender...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A56436)
PENDING SELLER...
