Box blade or rear blade
   / Box blade or rear blade #1
Captm
2022 Kioti DK4210SE
I have a plot of land that had all the trees harvested and stump removed last year. It it about 1 acres and I would like to make it flat to build a garage next year. It is not crazy hilly but its got a few spot that are higher than the rest. I am wondering what would be the best rear attachement that would allow to move soil arround and “equalize” everything. My soil is mostly sand. And I have a kioti dk42 with a FEL.
   / Box blade or rear blade #2
Either will work, easiest would probably be grading scraper(land plane) but that’s a more specialized implement so the others are more likely to be used for a subsequent project.
   / Box blade or rear blade #3
For just moving dirt, a Box Blade.
For moving dirt and equalizing a grade, a rear/angle blade pulled on a 45 degree angle.
Buy heavy.
   / Box blade or rear blade #4
If you don't need to do ripping then a rear blade with gauge wheel/s and side plates can be very versatile.
Sent from my SM-G715U1 using TractorByNet mobile app
   / Box blade or rear blade #5
Moving soil = box blade
Getting sticks and rock out of the soil = landscape rake
Rough Leveling and smoothing = back blade
Smooth as a baby's behind = land plane
   / Box blade or rear blade #6
I have all three implements - Rhino rear blade, Bush Hog ROBB & Land Pride LPGS. For me - the rear blade is the most universal and most used implement. Snow removal and roughing out a land projects. Pulling out gravel and associated crap from my driveway ditches. I use the ROBB to move lots of dirt and fill in swales, ditches, gullies, etc. The LPGS only has very specific uses. It will flatten and smooth the land surface - like a pool table. My LPGS has scarifiers so, if thing aren't too far out of spec, I can scarify, flatten and smooth - all in one pass.
It seldom is only one pass with the LPGS on raw land. I scarify and flatten. A second pass with scarifiers up - smooth as a babies butt.
   / Box blade or rear blade #7
A box blade is best for moving dirt. A grader blade is best for road maintenance and cutting ditches, etc… I used to own both, but sold the box blade because I no longer have any need for it. My grader blade is what I use all the time for road maintenance and some dirt leveling.
   / Box blade or rear blade #8
A rear grader blade with side wings might be an option that would make for the ability to move dirt and grade it. Also more versatile for multiple uses.
1997 Moxy MT30 Haul Truck (A55272)
1997 Moxy MT30...
2015 FREIGHTLINER CASCADIA DAYCAB (A58214)
2015 FREIGHTLINER...
Swict 66" Bucket (A57149)
Swict 66" Bucket...
2016 CATERPILLAR 304E2 EXCAVATOR (A52709)
2016 CATERPILLAR...
E-Z TRAIL S10 GRAIN CART (A52708)
E-Z TRAIL S10...
Yellow Steel Diamond Plate (A55758)
Yellow Steel...
