Box Scraper Box Blade on a Mahindra 28 XL HST
   / Box Blade on a Mahindra 28 XL HST #1
BudMan5
SW MO
Mahindra 28XL HSTJD 915E and JD D140
I need a box blade scraper and found a good deal locally, BUT! I have no experience with them. The one I am looking at is 6 foot wide and I am wondering if that is suitable for my tractor. If not, what size should I look for?
Thanks in advance!
   / Box Blade on a Mahindra 28 XL HST #2
Your 28XL is similar to my TC29DA as to size and specs. The standard width on your tractor is ~54.3". You want a box blade wider than your footprint. I have had no problems with my 60" box blade; I could have gone a little wider; a lot depends on intended use and type of dirt you will be engaging. Heavier is better.
I appreciate the reply and from everything I am reading it looks like I need to follow your lead.
THANKS!
   / Box Blade on a Mahindra 28 XL HST #4
A 60" would be a good match for your tractor, as heavy as you can afford. I highly recommend a ROBB.
71050 (A49346)
71050 (A49346)
43013 (A51691)
43013 (A51691)
(30) 9' Pipe Fence Posts (A50515)
(30) 9' Pipe Fence...
2021 JCB 3TS 8T SKID LOADER (A51242)
2021 JCB 3TS 8T...
2019 HINO 268 26FT BOX TRUCK (A52141)
2019 HINO 268 26FT...
