Box blade height adjustment problem
/ Box blade height adjustment problem #1
kmotexas
Needville
TC40 DA
Hi All,
I'm new to this forum and wondering about that eventual some one has the answer handy.
I have a TC40DA with Position Control problem. It is not more possible to pre-select the height of my rear tools.
Just all the way down on the position control level to lower the tool and than all the way up on the level to stop.
Never less to say it is not possible to stop allays at the same height....Thanks Klaus
/ Box blade height adjustment problem #2
Most 3pt controls have some kind of adjustment that limit how low the control will go so your implement will stop at the same height. Are you needing to stop the lower limit or the upper limit?
/ Box blade height adjustment problem #3
So if you have your PC lever in the middle, what happens?
Thanks for the respond (-:
I did found the problem.
The position limiter link to the hydraulic block is broken......)-:
Looks like the limiter valve is frozen solid.
Hope some DW40 will do the trick.
After this I just need to weld the limiter link back to the valve.
Thanks
Klaus
(INOP) BOMAG BMP8500 TRENCH COMPACTOR (A60429)
(INOP) BOMAG...
(2) 4 WAY WRENCHES (A64276)
(2) 4 WAY WRENCHES...
John Deere 772-A Grader (A62679)
John Deere 772-A...
2017 Caterpillar 308E2 (A64126)
2017 Caterpillar...
2011 UD Thermoplastic Truck (A64194)
2011 UD...
213137 (A64276)
213137 (A64276)
