Grading box blade for my 2210
   / box blade for my 2210 #11
Sounds like maybe the 'L' thing is over-rated. I'm not sure what the difference in height is on the limited category 1, but now I'm wondering if the lighter weight of the L stuff isn't a down side - seems like a couple of hundred pounds heft would be of help with a box blade - I'd think that the heaver device stands up better agains the ground.
Does the Woods have a fixed back blade?
   / box blade for my 2210 #12
JohnnyTractor,
You're right that more weight makes the BB work better (less "floating" over high spots instead of cutting into them). But I found that the "L" models still cut a big bite into the ground, with a sacrifice of box capacity. Without any additional weight my GBC48 will float at times, however sometimes this actually helps. If I need more cut off I just go back over it.
It was hard comparing full size to the subcompact, as I found out that many dealers do not stock the smaller ones. The GBC48 seemed to be a "in the middle" size in regards to box height, which is what I was looking for. The heavier BB's are obviously more heavy duty, but don't dismiss the smaller ones as inadequate. They too are well made and match well with this size tractor. When I need more "bite" I just add more weight.
So I found that more weight does make the BB work better. And yes, my Woods does have a fixed back blade.
Hope this helps.
   / box blade for my 2210 #13
Thanks a lot for posting the pictures of your BB in use. Though raised on a farm, and with many hours of seat time, I've never seen a BB used here in my part of NH. The dealers are beginning to stock them, so I guess use is on the rise. I wondered how they would work in sod.
Link-Belt 75X3 (A53317)
Link-Belt 75X3...
2016 Caterpillar 349FL Hydraulic Excavator (A56857)
2016 Caterpillar...
2019 Haulotte Star 20 ACE 19ft Scissor Lift (A55973)
2019 Haulotte Star...
MARATHON 25KW GENERATOR (A58214)
MARATHON 25KW...
New Holland 650 Hay Baler (A53317)
New Holland 650...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
