box blade for massey 165
   / box blade for massey 165 #1
fordman6442
Terrace B.C. Canada
67 massey 165,1947 Farmall A, 1949 Massey Harris, 1955 Ford 600 with b/hoe and loader J.D. 350 Crawler with winch and 6 way blade,Kabota riding mower, Husquavarna riding mower,Kawasaki quad and a wife
Anyone have plans to self build a box blade? What sise will my Massey 165 handle. I live up north in British Columbia and to buy and ship one would cost too much. Thanks
   / box blade for massey 165 #2
It should easily handle a 7' blade. I do not have any plans but search the forums and I am sure you will find enough info to come up with your own design which is part of the satisfaction you get from being self-relient. An idea for the tub portion would be to use an old fashioned well pressure tank (large like the one I just scavenged from a demo job)with 4" box tubing with shank cut-outs (shanks you can buy) in it welded across the front. then tabs for the lower link arms welded to the box tubing, an a-frame made out off 3/8" x 3" flat stock for the center hitch, a brace back to the back in the center, buy a bolt-on cutting edge and re-inforce behind the tub for the cutting edge with more steel.
Or find a used one locally (as this will probably be cheaper).
Paul
Paul
Zimmerman 6 Lug Running Gear (A50774)
Zimmerman 6 Lug...
2014 Dodge Avenger Passenger Car, VIN # 1C3CDZAB4EN223470 (A50324)
2014 Dodge Avenger...
2004 Ford E-250 Cargo Van (A50323)
2004 Ford E-250...
LONG 445 TRACTOR (A51243)
LONG 445 TRACTOR...
2007 FORD F-750XL SUPER DUTY DUMP TRUCK (A51243)
2007 FORD F-750XL...
(30) 9' Pipe Fence Posts (A50515)
(30) 9' Pipe Fence...
