Grading box blade for B7610
   / box blade for B7610 #1
JHohler
Atlanta Metro Area
Kubota B7610
I am getting ready to purchase a box blade for my B7610. Any recommendations on width? The manual calls out a 54", however most implement manufacturers offer either a 48" or a 60". Seems the 54" width is an odd size. Is a 60" box blade too big for the B7610?
   / box blade for B7610 #2
I have a 60" box blade on my B7610. I primarily use it to keep my whiterock drive leveled. I'm speaking with limited experience as I've only had a compact tractor less than 1 year but I think it depends upon what you're using it for and how deep you set the scarifiers. I'm planning on adding a set of guage wheels as if I'm not careful it's easy to drop the blade too deep and really drag down the tractor. I was losing c clips on my 3 point until I figured out that I was just overloading the 3 point with too much of a load in the box scraper. Raised it up along with the scarifiers and to date no more trouble keeping the clips on. Bottom line is that I think it's all in what material you're working with and how you use the scraper.
Hagman
B7610 w/FEL, MMM & 5" Box Scraper
   / box blade for B7610 #3
I agree with Hagman. I have a 60" box blade on my 7610. I can bog it down pretty good if I try to use it too aggressively but by taking smaller bites, the 7610 can handle the 60" very well.
Regards,
Duber
Toyota 6FGU25 Forklift  5,000 lb Capacity (A51039)
Toyota 6FGU25...
2021 CATERPILLAR 259D3 SKID STEER (A51242)
2021 CATERPILLAR...
2016 Big Tex 14LX 14ft 7 Ton T/A Dump Trailer (A50322)
2016 Big Tex 14LX...
2014 Ford F550 Crane Truck (A50323)
2014 Ford F550...
2017 Ground Hog HD99 Towable Hydraulic Auger (A49461)
2017 Ground Hog...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A51039)
80in HD Tooth...
