Grading Box Blade for B2910
   / Box Blade for B2910 #1
dlockh4258
Lexington Kentucky
Kubota B2910
I have a B2910 and was wanting to get a box blade for it. What size should I get. I have the B2910 with turf tires. I would like some input on which brand and what size would be the best for my trator. Thanks
   / Box Blade for B2910 #2
I think you would be well-served with a 5' boxblade. I would not go too much larger. A 5' will cover your wheel tracks.
How durable a boxblade to get depends on what you expect from it.
For example, I use mine to grade my driveway, and a neighbor's. I also use it for light landscaping work and, with the rippers all the way down, use it to rough "till" my garden. I would consider my use to be fairly light duty. Accordingly, I bought a locally produced boxblade that is approximately equivelant to the light duty models sold at Tractor Supply. These models can be had for about $350.
Heavier-duty models can be quite a bit more expensive, but the concensus here seems to be that they are definitely worth it if you need that kind of capability.
   / Box Blade for B2910 #3
If you look in your owners manual there should be a section where they detail all the major implements available and what size they recommend. I use a 5 footer on anL2500 and think you could probably use a 6 footer but maybe not with the turfs (I have ags). Too big is better than too small as you can always take a smaller bite if you start to spin. (Only an issue with the rippers down). As with most implements the heavier the better, I use an extra 250 lbs of steel weights on mine to help it bite better in hard dirt.
   / Box Blade for B2910 #4
David
I have a Land Pride BB1560 for my 2910. I do not have any problems using it with turf tires. I do need to use FWD for the best results.
   / Box Blade for B2910 #5
Try this post</font color=blue> "Boxblade price check and more..." under attachments.
I hope that works, I never did a link before.
I have a Woods HB60 on my B2910, but I really haven't had much chance to use it. Our ground is so hard that I figured I could use whatever extra weight I could. I have R4's on my tractor.
~Rick
   / Box Blade for B2910 #7
i use a 6' lienbech hd box on my 2910. it weighs in at about 500 lbs. it works great for greading the drive and some landscaping chores. i woudnt got any smaller but i do not work comercially with my machine.
John Deere 1775 NT Exact Emerge 24 Row Corn Planter (A52349)
John Deere 1775 NT...
2018 INTERNATIONAL 4400 SBA 4X2 SERVICE TRUCK (A51406)
2018 INTERNATIONAL...
UNUSED FUTURE 5T HYD THUMB CLAMP (A51244)
UNUSED FUTURE 5T...
Case Ih 1660 Combine (A50514)
Case Ih 1660...
2020 CATERPILLAR 301.7CR EXCAVATOR (A51242)
2020 CATERPILLAR...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
