Box Blade dropping
   / Box Blade dropping #1
DCS
Bronze Member
Angleton, Texas
JD 4310
I know this topic has been discussed, but I couldn't find it. My box blade on my JD 4310 sometimes will not stay up. The handle to raise it up also falls to the bottom position. What's going on you think?
   / Box Blade dropping #2
Do you have any kind of friction disc, or nut on the 3pt quadrant ahndle to adjust tension? For sure if the control handle falls.. it is going to tell the system to drop the implement.. etc.
Soundguy
Yep, I bet that's it. Didn't think about that, I going to check it right now. Thanks
Nope, that wasn't it or at least I couldn't locate any kind of friction nut.
   / Box Blade dropping #5
Does it hold when the tractor is not running?? When you move the arm is there a drag?
murph
It works fine at times but I check it out this afternoon and it falls to the lower position even when the tractor is not running. There is no drag when when you move the handle back and forth.
   / Box Blade dropping #7
Your missing something then. There should be some kind of drag on that arm. Get your manual out and look to see if there is an adjustment listed or go to your dealer and have him look in his parts manual.
murph
I guess I am going to have to go the dealer as soon as I get through with these last six loads of sand.
   / Box Blade dropping #9
There should be a friction disc or some other sort of tensioner device on the 3pt quadrant handle.
What actually holds the handle on?
Soundguy
   / Box Blade dropping #10
i might help if we knew what type of tractor you have (in your sig works well)
HARDEE RD72M LOT NUMBER 154 (A53084)
HARDEE RD72M LOT...
2018 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2018 Allmand...
2013 FREIGHTLINER CORONADO TANDEM AXLE DAY CAB (A52576)
2013 FREIGHTLINER...
2020 Takeuchi TL10V2 (A47384)
2020 Takeuchi...
2000 Toyota Tacoma Pickup Truck, VIN # 5TEWN72N6YZ690085 (A51572)
2000 Toyota Tacoma...
2015 DODGE RAM...
