Box Blade/Driveway Question
   / Box Blade/Driveway Question #1
koziol41
I want to make a gravel driveway off one end of my black top driveway.It would be a drive just to get to my pasture gate there is all grass there now would a box blade work on getting down deep enough to add gravel only have to go about 30' i really dont want to pay someone to do it.buying the gravel would be ok.Any comments or suggestions.have a JD 2520.
   / Box Blade/Driveway Question #2
Best way, is to remove the grass, then bring in about 3" of rock and spread it. If you dont remove the grass, it will come through the rock, it might anyway, if you dont put something to kill the grass.
Would the BB remove the grass?And would it remove maybe a couple inches of dirt so then i can spread the gravel?
   / Box Blade/Driveway Question #4
Yeah.. that's a box blade kinda job for a homeowner..
soundguy
   / Box Blade/Driveway Question #5
Yes, a perfect job you can yourself with your boxblade.
You might consider using the rippers down about 2 or 3 inches to cut the grass and break up the soil. Then scrape it off and smooth it. I would put some kind of pre-emergent down to keep the grass from coming back. Then use the boxblade to drag layers of gravel over it until you have the thickness you want.
You could even tilt your boxblade sideways using the side links and cut a small ditch next to the drive for water drainage.
   / Box Blade/Driveway Question #6
I agree with everybody else a BB will work just perfectly. Just remove a few inces of the top soil and put 2" - 6" of gravel down.
You will get grass eventually even with the herbicide not unless you do it every year with the stuff that kills up to a year.
Hey Everybody Thanks for the info.It is nice to be able to do things like yourself s paying someone.AHHHH Tractors and Equipment SOOOO Much FUNN!!!!!!
   / Box Blade/Driveway Question #8
Oh.. you are paying for it.. it's just that the price of the tractor gets spread out over all the jobs you do with it.
good luck and have fun.
soundguy
   / Box Blade/Driveway Question #9
Planning on doing a similar project after I do some drainage work. Ordering 25 tons of 1 1/2 stone. If I have any left after the drainage, I'll dig down a few inches drop whats left of the stone and finish off with item4.
Lots of good info.So i guess to figure how much gravel i need i take the driveway WXLXD and convert to yards??? is that correct???
2006 Utility 3000R 53ft T/A Reefer Trailer (A51694)
2006 Utility 3000R...
Towable generator (A52377)
Towable generator...
1985 Miller Wildcat 350-D Welder (A51691)
1985 Miller...
2016 Ford Fusion Sedan (A53424)
2016 Ford Fusion...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A53473)
NEW HOLLAND 706 30...
1987 CASE IH 9150 TRACTOR (A53843)
1987 CASE IH 9150...
