Grading Box Blade Decision? Bush or LandPride and/or Rollover?
   / Box Blade Decision? Bush or LandPride and/or Rollover? #1
ids
Hi,
I was wondering if anyone might be able to help me decide on a box blade, the problem is I have the specs, I just don't know if my tractor can support it - I will be in the process of building about a 1mile dirt road..
I am going to get a Kubota L5240, 4WD HST, and I was thinking about getting the Land Pride BB1572 at 504lbs, or the BB2566 at 500lbs....however, I just came across someone who would sell me a Bush Hog, MBX-960 at 790lbs, for only $650, its used but looks really good...
My problem is the difference in weight is almost 300 lbs, and could the L5240 really handled it....I;m not really good at reading specs, but from the Kubota site, it says, PTO 540rpm, and under Hydraulic, it reads Lift capacity at 24in behind lift point - 2976lbs...Does this mean the PTO lift capacity could easily handle the Bush Hog MBX-960, or does that refer to the front loader?
oh, and someone mentioned that I should look at a Bush Hog - Roll over box blade...any idea what a roll over blade is?
thanks again
steve
   / Box Blade Decision? Bush or LandPride and/or Rollover? #2
a six foot box would be good a seven foot ok and 8 footer I think would be to much for road building. you would have a hard time pulling a full box.
Jeff
   / Box Blade Decision? Bush or LandPride and/or Rollover? #3
Hi,
thanks again
steve
There is no such thing as "PTO lift Capacity" What this is saying is the 3 POINT HITCH HYDRALIC LIFT ARMS can lift 2976 lbs. So yes this machine can lift a 790 lb box scraper
PTO is Power Take Off---it's a spindle at the back of the tractor that works off the tractor's transmission and can power implements such as a Rotary Mower (AKA Bush Hog), Finish mower, Post hole Auger etc. PTO has nothing to do with the lift arms or a box scraper.
6' Brush Hog 3 pt Mower (A50515)
6' Brush Hog 3 pt...
2019 Chevrolet Tahoe SUV (A50324)
2019 Chevrolet...
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
CASE 1150G (A47384)
CASE 1150G (A47384)
(4) Stand Alone Texas Panels (A50515)
(4) Stand Alone...
Kubota BX2680 Sub-Compact Tractor  4WD, 218 Hours (A52748)
Kubota BX2680...
