Box Scraper box blade as harrow?
   / box blade as harrow? #1
Diesel_Boy
Central Maine
with a box blade, could the top link be shortened, the teeth dropped down as low as they will go, and used as a harrow on a small garden plot?
   / box blade as harrow? #3
Diesel Boy:
A poster called 3RRL used his box blade extensiely as a harrow with great results on a very large area :). I have used mine like Timber. Jay
   / box blade as harrow? #4
I tried something similar but my blade's teeth wouldn't go nearly low/tilted enough, even with the rippers all the way down and the link all the way short. So I think it might depend on your particular setup.
   / box blade as harrow? #5
Depending upon your equipment, you might have to buy a shorter toplink. I've seen Cat 1 toplinks as short as 13" (body), I think your Kubota is 14.5"
But yes - when the geometry can be made to work, the chisel points perform an excellent (albeit narrow) harrowing job.
//greg//
   / box blade as harrow? #7
Not having my own plow, trying to beat some rain and particularly being lazy in not wanting to drive 5 miles to a friend's house that does have one, I decided to try "plowing" a little over an acre with my 7' box blade rippers. It did a decent job of tearing up a severely packed sandy/clay pasture that had been trampled by cattle for the past 6 or 7 years. After I plowed, I used my 7 1/2' disc harrow to till the soil even further. Now several months later I have an exceptionally nice looking food plot.
Next year I'm going to deep plow this and other fields to really prepare the soil and bring up trapped nutrients.
   / box blade as harrow? #8
I'm with Heymack! I've done some pasture renovation prior to a re-seeding exactly as Heymack described. If I start with my box bade set up correctly I can use the teeth to break up the hardpack to a depth of about 2.5-3 inches. I then run my small two gang disc harrow over the same space to create a pretty nice bed ready for re-seeding.
It's no tiller, but it gets me to where I need to be with the equipment I have.
   / box blade as harrow? #9
I, have had pretty good results, with my tooth bar, dragging in reverse
Ray
Texas Post Driver Series 500 Heavy-duty Hydraulic Post Driver (A52128)
Texas Post Driver...
2023 CATERPILLAR 279D3 SKID STEER (A51242)
2023 CATERPILLAR...
2024 Spartan KGZ-XD Zero Turn Mower (A50514)
2024 Spartan...
2013 Ford F-550 4x4 Ext. Cab Auto Crane 6406H 6,000LB Crane Service Truck (A50323)
2013 Ford F-550...
2018 MDB T5E MDB DISC MOWER (A51243)
2018 MDB T5E MDB...
2015 CATERPILLAR D6K2 XL CRAWLER DOZER (A51242)
2015 CATERPILLAR...
