Toplink Box Blade and Hydraulic Top Link
   / Box Blade and Hydraulic Top Link #21
Yes, it looks like this. BTW, what is check valve?
   / Box Blade and Hydraulic Top Link #22
<font color="blue"> BTW, what is check valve? </font>
A check valve only lets fluid flow in one direction.
   / Box Blade and Hydraulic Top Link #23
Sorry, wrong made question. Right question is: what dou you call check valve? We call it here (single)direction valve. Thanks.
   / Box Blade and Hydraulic Top Link #24
Stumbled across this tonite while searching for hydraulic top link. Shows that valve the has been mentioned. To bad everything is is in metric /forums/images/graemlins/crazy.gif. At least the Euro is easier to convert to dollars /forums/images/graemlins/wink.gif
   / Box Blade and Hydraulic Top Link #25
There is a difference in check valves. A check valve proper allows hydraulic flow only in one direction. A pilot operated check valve allows flow in both directions once a preset pressure has been reached. The pilot operated check valves are used as a safety device for broken hydraulic lines and they will also stop most of the movement due to hydraulic bleed by in tractors. This is the valve you want to keep your loader from bleeding down or to keep a top and tilt from moving during operation. I would not sell a hydraulic toplink without a double pilot check valve.
<font color="red"> Cat 1 Toplink 18-26" with double pilot check valve = $150
Cat 1 Toplink 21-32" with double pilot check valve = $170 </font>
   / Box Blade and Hydraulic Top Link #26
</font><font color="blue" class="small">( <font color="red"> Cat 1 Toplink 18-26" with double pilot check valve = $150
Cat 1 Toplink 21-32" with double pilot check valve = $170 </font> )</font>
Can those double pilot check valves be retrofitted easily to an existing hydraulic toplink?
I've already got a toplink, which I had to get modified to get the correct length range for my tractor (15"-23"). It's working great, but I do get some movement under load.
John Mc
   / Box Blade and Hydraulic Top Link #27
I may be interested in one of your toplinks. What size cylinders? What would shipping be to Cambridge,OH?
   / Box Blade and Hydraulic Top Link #28
Thanks Mark.
"Pilot operated check valve" is valve which I tried to describe before. /forums/images/graemlins/wink.gif
I know it like "stop valve", so I made confusion using wrong name. /forums/images/graemlins/frown.gif
   / Box Blade and Hydraulic Top Link #29
CCI
I'm very interested in you HTL with the double pilot check valve. I"ve started a HTL thread under customization forum. There are a few questions that I have posted about HTL.
   / Box Blade and Hydraulic Top Link #30
Check your dealer
before fabbing too much. $200 installed on my TC33D!
Towable Orchard Sprayer (A55851)
Towable Orchard...
UNUSED FUTURE FT36C STAND ON SKID STEER (A52706)
UNUSED FUTURE...
2007 Ford Five Hundred SEL Sedan (A55853)
2007 Ford Five...
3410 (A47477)
3410 (A47477)
MISC CABINETS FLOORING (A54757)
MISC CABINETS...
JOHN DEERE 4066R LOT NUMBER 23 (A53084)
JOHN DEERE 4066R...
