RayCo
Veteran Member
- Joined
- Jul 24, 2005
- Messages
- 1,039
- Location
- Chester County, PA
- Tractor
- Kubota BX24, Case 580 Super L
I'm thinking about replacing the lift arms on my 3pt hitch with chains in order to help keep my box blade from being affected by the tilting and rocking of my tractor as I drove over my less-than-ideal terrain that I'm working in. I'm trying to change the contour of the ground that I'm digging out, but it doesn't really seem possible to do with the rigid connection, since as the tractor follows the contour, so does the blade. Short of the top-n-tilt solution, are chains something that can help? I have a 4 ft blade that weighs about 250 pounds, I believe. I was thinking of doing chains and also adding 150 pounds of weight to the box blade. Should I expect this to be effective?
