Box blade and 3ph for x728 finally here
   / Box blade and 3ph for x728 finally here #1
msengstock
Connecticut
JD X728
Will take a bit getting used to the hydraulic setup with the 3 ph ... the lock out that would lock out the mower deck while using the loader gets bypassed or something, so you have to becareful when rolling the bucket - if you doing it gently or past the detent which I think is the regen position, the 3ph won't move, but if you aren't carful, when you dump your bucket, you'll also drop the 3ph down all the way and the ballast box or box blade will drop down to the ground ... kinda wierd, but I guess that's how it works now and it'll take some getting used to. The lock out was nice, wish they could have kept it fuctional.
Here she is:
RHINO DB150 LOT NUMBER 73 (A53084)
RHINO DB150 LOT...
2018 Bobcat E26 Mini Excavator (A55787)
2018 Bobcat E26...
Kuhns AE10 Small Square Bale Accumulator - 10-Bale Efficient Handling System (A55301)
Kuhns AE10 Small...
Mohawk 12,000lb Two-Post Electric Auto Lift (A55851)
Mohawk 12,000lb...
SKID STEER HYDRAULIC TREE PULLER (A53843)
SKID STEER...
(APPROX 104) 2X4X10 PINE LUMBER (A54756)
(APPROX 104)...
