Box blade adjustment
   / Box blade adjustment #1
sgipson
south mississippi
ford 3600 1974
Box blade on Kubota m5040 very hard to adjust tilt side to side
Can turn lower link small amount
Any trick to this?
   / Box blade adjustment #2
Are the threads clean, as in not rusted?
Let the box down on the ground, get some weight off the hitch, adjust accordingly.
   / Box blade adjustment #3
Depending on the condition...you might consider taking off the adjustable side link and extending it all the way and wire brush and lube the threads...
   / Box blade adjustment #4
I adjust mine with the tractor running...lift or lower the box blade where it just hits the ground to relieve the pressure on the link. When you hit the sweet spot I can usually turn the link by hand. If the other side of the box hits the ground first, put a block under the side with the link so it will take the weight of the box and give it another try.
   / Box blade adjustment #5
Lift up the box blade, put a 4-6" log in the middle of the box blade (running with the tractor) set the box blade down on the log ever so slightly to relieve the pressure but not to rest too much of the box blade weight on the log...
   / Box blade adjustment #6
You're so wise Mr. Old and Tired!
2019 Fontaine Traverse HT T/A 48ft. 41 Ton Hydraulic Dovetail Equipment Trailer (A49461)
2019 Fontaine...
2020 Peterbilt 389 Tri-Axle Sleeper Cab Truck Tractor (A49461)
2020 Peterbilt 389...
2012 Ford F-150 Crew Cab Pickup Truck (A49461)
2012 Ford F-150...
2006 CMI C125-1 Ride-On Forestry Mulcher (A49461)
2006 CMI C125-1...
2019-2024 Dodge Ram Front Bumper (A49461)
2019-2024 Dodge...
2018 PJ  30+5 GOOSENECK TRAILER (A50854)
2018 PJ 30+5...
