Bought new pickup should I get it undercoated ?
   / Bought new pickup should I get it undercoated ? #81
That makes sense. But it also looks like it would catch a lot of mud and debris.
I'd be interested in knowing what the dealer recommends / suggests for a new truck.
Also wonder if they install the after-market plastic wheel-well liners over the carpet / fabric or if it has to be removed. Looks like installing plastic to protect it and still have the sound-deadening quality would be the best of both worlds.
Thanks for the info.
What?
An 80K PU and U question rust proofing?
Shucks I'd be tempted to rust proof 3/4 x /yr with best policy published!
What?
$80,000 ? My new f150 XLT four wheel drive 2.7 liter eco boost with 10 speed automatic transmission with tonneau cover, bed liner and mud flaps installed , also a trailer hitch and running boards cost under $52,000 and that includes tax and license. Tomorrow I’m going to ask about maybe removing the brandnew running boards and selling them.
   / Bought new pickup should I get it undercoated ? #83
If you have a vehicle with a unibody, live in the north where deicing salts are used, want to keep your vehicle for 6+ year, please apply an undercoating as early as possible from the purchase date to protect yourself! In Vermont anyway, a car will likely fail the required annual State Inspection, due to rust after 7 years, if you do not undercoat each year. Another revenue source for the State!
   / Bought new pickup should I get it undercoated ? #84
Fluid Film or equivalent is needed to minimize rust.
However I have always been totally amazed (with all due respect for those on this forum) at how people will spend $50k-$80k on a truck and then it rusts away. To me this is a scam by the manufactures and nobody seems to question it.
   / Bought new pickup should I get it undercoated ? #85
I have often wondered the same thing about critical components of a vehicle. Not necessarily just the body.
When buying a $80k truck.....what would the upcharge be to use stainless steel brake and fuel lines? Or exhaust? A drop in the bucket all things considered?
   / Bought new pickup should I get it undercoated ? #86
Stainless lines, and never-seize on non-critical fasteners. I agree.
From a business perspective though, the auto industry gets hammered with safety, economy, and emissions regulations. They need to market a vehicle that appeals to the masses, meets regulation and is at least reasonable in price. Not to mention the many frivolous lawsuits due to incompetent drivers. It's always the car manufactures' fault. I can see why rust prevention is a lower priority.
Over the last 40 years the de-icing chemicals have gotten more effective and more corrosive. In conjunction with wasteful and ridiculous government spending protocol (use it up this year or we won't get more next), and you have a recipe for vehicle and environmental disaster.
BTW - just got the 2022 Canyon coated at NH Oil Undercoating. I have mixed feelings. Let's say that they were extremely through with application and lack-luster on clean-up. I'll be cleaning windows and washing it it multiple times. Black oil undercoating on a white truck was my mistake.
   / Bought new pickup should I get it undercoated ? #87
7 years might be a bit of an exaggeration, but yeah, rust remains a problem on vehicles.
Didn't Vt. experiment with reduced salt usage a few years ago? ISTR seeing signs to that effect when crossing into the state. Haven't seen them for a while...must not have worked out very well.
Our snow here in the northeast usually has a high water content, and if roads are untreated turns to ice/hardpack when you drive on it. Not sure how things are in western states where the snow is drier.
Actually, rust resistance is a lot better on vehicles than it was 30+ years ago. Japanese vehicles were the worst, American & European ones were better, but even so 10 years was a long time for a vehicle.
Trouble is, just when the manufacturers started to provide better rustproofing, the states switched from using rock salt to treat roads to brine, which gets in every little crevice and stays there. The plastic cladding most automakers use on rocker panels and around wheel wells not only traps it, but you also don't notice it until it's bad.
Fortunately, the town I live in uses very little road salt, but this is a winter tourist area (snowmobiling, skiing) and the state more than makes up the difference on state/federal roads.
   / Bought new pickup should I get it undercoated ? #88
tried scraping and painting with rust converter twice at huge expense. It hardly slowed the rust down
That's because that crap dosnt work. You cant get in the seams and the prep is the same for new paint.
   / Bought new pickup should I get it undercoated ? #89
as a retired mechanic..... absolutely no. what a mess to work on.
You would rather fix stuck bolts, rusted bolts or scrap the vehicle vs getting a bit dirty?
   / Bought new pickup should I get it undercoated ? #90
In Pa. salt and deicers are heavily used. I had my new GMC done by a shop that uses causmline like the military uses.
2000 Sterling L9513 Winch Truck (A56438)
2000 Sterling...
2020 CATERPILLAR 306 CR EXCAVATOR (A60429)
2020 CATERPILLAR...
pressure washer, and trailer (A56859)
pressure washer...
500 Gallon Fuel Tank with Pump (A55853)
500 Gallon Fuel...
2014 GMC Sierra SLT Crew Cab Pickup Truck (A59230)
2014 GMC Sierra...
2010 Dodge Ram 4x4 Crew Cab Pickup Truck (A59230)
2010 Dodge Ram 4x4...
