Rotary Cutter Bought myself a rotary cutter
   / Bought myself a rotary cutter #11
I have a Rhino TW72 bought it used I am third owner
I have a slip clutch on the the drive shaft. It works great on large stuff up to about 4" or a little bigger. But when I cut tall thick grass, it cuts most of it, but leaves some of it a bit tall some after a single pass may be 12 to 16 " high it's usually a strip on the right side of the gear drive. Is this typical of this mower? I have a smaller lighter mower 48" which leaves a nicer cut. I was wondering if something is bent on the mower yoke or blades ? Or is this typical for this mower. Thanks for any help..........
Mine always left a windrow in really thick stuff, I just double cut it. I finally wore mine out, the deck is rusted out in more places than I want to repair. I bought a flail and couldn't be happier with it. It won't cut 5" trees but, the cut quality is far superior to the Rhino. I have a skid steer with a forestry mulcher for the nasty stuff now.
   / Bought myself a rotary cutter #13
If it was just a windrow I wouldn't mind, Its more like it leaves the grass after the first pass about 8 to 12 high and if I back up and then pull forward it is cut to my satisfaction. I was just wondering if something was bent or does the TW72 just cut grass this way because its more for cutting Brush than grass? I have sharpened the blades and it's not helped much. But I love how it destroys the 3 to 5 inch branches of some big brush. I have a flail mower but don't want to mess it up by hitting a big chunk of a branch from the brush that may be hidden in the tall grass. I am hoping to get all the big stuff picked up so next year I can us my flail in the tall grass. The flail came with my tractor but I have not used the flail yet. My smaller 48 inch lite weigh mower does a way better job but I like using the 72 inch for more coverage. And the 48 inch mower needs some reinforcement on it exterior sheet metal as I live on the Coast and the salt air has taken its toll on it. It is good for lighter work I usually pull it with my smaller Kubota which doesn't have power steering, where my M5140 with power steering is a lot easier on my 75 year joints at the end of a long day of cutting.
   / Bought myself a rotary cutter #14
It's normal to have "stick ups" and clumping after cutting tall heavy grass. If you're after a cleaner finish you'll probably just have to cut it again. I'm only cutting rough pastures with mine, so I'm not after a nice finish cut. There are other deck designs that are supposed to help with the clumping, but the typical cutter deck is going to do it.
I also think the batwing style decks are supposed to leave a better cut behind. At least the ones I've been looking at do.
Yeah, it's not a finish mower, it's for rough cutting. Mine never left a pretty cut but, it cut whatever I could drive over. Like I said, I just double cut if I wanted it to look nicer.
By windrow, I meant strips of taller grass.
   / Bought myself a rotary cutter #16
Similar unit to my Bush Hog 286. I got my 286 for $800, but had to invest in a new PTO shaft and have the tail wheel bracket welded: put me close to $1,100. The deck was pretty much punched through and came with a thick steel plate welded on top of the deck (previous owner used it commercially, to MOW ROCKS!). There are almost NEVER any 6' RCs for sale in my area: I was fortunate to have run into the one I got. A comparable new unit will run somewhere in the neighborhood of $3,500.
Redirective Crash Cushion Guardrail (A55852)
Redirective Crash...
2018 John Deere Z997R (A53317)
2018 John Deere...
2015 PETERBILT 579 TANDEM AXLE SLEEPER (A56138)
2015 PETERBILT 579...
2007 INTERNATIONAL 4300 26FT BOX TRUCK (A56138)
2007 INTERNATIONAL...
2 Warehouse Forks (A55787)
2 Warehouse Forks...
2018 RAM 2500 SERVICE TRUCK (INOPERABLE) (A55745)
2018 RAM 2500...
