Bought an old Ford 4500 TLB - how do I keep from breaking it?
   / Bought an old Ford 4500 TLB - how do I keep from breaking it? #11
Good advise given so far. The two weakest links IMO are the loader and swing chain. Its rare to see o e of them loaders that don't have several patches,welds, or other repairs. Don't use it like a bulldozer or ram into things. The swing chain is also a weak and expensive link. Try not to use it to swing the whole machine around. If you didn't line up right pull forward and try again. And minimize using swing to backfill.
   / Bought an old Ford 4500 TLB - how do I keep from breaking it? #12
If hard to reach hoses need replacing, possibly you could attach the new hose to the old one and pull it into place while you pull out the old hose. Just thinking out loud.
I'm finding 2 u-joints on the shaft from the crank to the hydraulic pump. One has a grease fitting, the other doesn't. That's not to say the other isn't missing one - the entire front end is caked in grease and dirt. Going to clean it out while we have the tractor apart. I've found a couple of fittings on the hoe to be non-functional. So far, the rest seem to be ok. Haven't hit them all. I do need to replace the bushings between the two main booms on the hoe (not sure of the technical terms). Right now, getting the engine back in working order is the priority.
2016 Husqvarna YTA22V46 46in Riding Mower (A56859)
2016 Husqvarna...
Caterpillar D6K LGP (A53317)
Caterpillar D6K...
40ft High Cube Shipping Container (A57453)
40ft High Cube...
2016 Kawasaki Mule KAF620S 4x4 Utility Cart (A55973)
2016 Kawasaki Mule...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55315)
NEW HOLLAND 706 30...
2015 GMC Terrain SUV (A56859)
2015 GMC Terrain...
