Bought an old 7 1/2 foot Meyers plow for tractor
   / Bought an old 7 1/2 foot Meyers plow for tractor
It's that bad? Maybe paying someone to sand blast it is worth it then...
I figured out which bolts I need to attach the 3/4" thick front plate to the frame on the front of the tractor. Once I bolt the plate on, I can start welding. I still have to install the 220vac circuit from my basement where the breaker box is out to the garage. I bought the breaker and wire Monday. I should have the 220vac circuit done this weekend so I can plug in the arc welder. I'll take some pictures before I start. Still making progress...
Howard
   / Bought an old 7 1/2 foot Meyers plow for tractor #22
Yes, but sounds like the waterpressure sandblaster as Mike linked would avoid the hassles and health concerns associated with dry sandblasting. I have an old pressure washer that needs a new wand and now I'm tempted to go that route too after seeing the info. (Also, forgot to mention, the prices I noted earlier did include one primer coat.)
   / Bought an old 7 1/2 foot Meyers plow for tractor #23
I picked up a siphon-based dry sandblaster that I used in conjunction with my 30 gal Craftsmen 110V air compressor. I worn a $40-$50 breathing filter mask (like what you would use for applying stains and varnishes) along with a full face mask to cleanup a mowing deck once. It worked well, but as has been mentioned, it makes a horrific mess. I never ingested/breathed a single grain of sand.
Polaris Sportsman 500X Four Wheeler (A57453)
Polaris Sportsman...
2018 Ford Explorer AWD SUV (A56859)
2018 Ford Explorer...
Lot 14 Boxend wrenches and other wrenches (A59213)
Lot 14 Boxend...
IRMC High-End Massage Chair (A57149)
IRMC High-End...
FUTURE D-PDQ 47" LAND LEVELER (A58376)
FUTURE D-PDQ 47"...
Air Compressor (A57149)
Air Compressor...
