Bought a used DK45 - 1st check up routine?
   / Bought a used DK45 - 1st check up routine? #1
CajunRider
Platinum Member
Cajun Land
Kioti DK45
I just got a used DK45. Usually when I buy a used car, I give it an around around service. This is my first tractor, what do you suggest?
   / Bought a used DK45 - 1st check up routine? #2
What I would do is to change all the fluids and filters. You really have no way of knowing if this was done or not on a timely basis. Make sure you find all the grease zerks and give them some good shots of grease. I would consider changing out the antifreeze/water mixture as well because some of the anti corrosion factors may be worn out at this point.
Some money spent now may mean a lot more longevity.
Oil and grease are pretty inexpensive in the long run.
Make sure you check the front axle oil as well.
Enjoy!
John
12 FLATBED W/ 300GAL WATER TANK (A50854)
12 FLATBED W/...
2007 MACK GRANITE ROLL OFF TRUCK (A51222)
2007 MACK GRANITE...
2010 Keystone Cougar 5th Wheel T/A Travel Trailer (A48082)
2010 Keystone...
Komatsu WA270-8 Articulated Wheel Loader (A49346)
Komatsu WA270-8...
Knapheide Service Body with Liftgate (A49461)
Knapheide Service...
2016 FORD F-250 SUPER DUTY SERVICE TRUCK (A51243)
2016 FORD F-250...
