Bought a used DK45 - 1st check up routine?
   / Bought a used DK45 - 1st check up routine? #1
CajunRider
Platinum Member
Cajun Land
Kioti DK45
I just got a used DK45. Usually when I buy a used car, I give it an around around service. This is my first tractor, what do you suggest?
   / Bought a used DK45 - 1st check up routine? #2
What I would do is to change all the fluids and filters. You really have no way of knowing if this was done or not on a timely basis. Make sure you find all the grease zerks and give them some good shots of grease. I would consider changing out the antifreeze/water mixture as well because some of the anti corrosion factors may be worn out at this point.
Some money spent now may mean a lot more longevity.
Oil and grease are pretty inexpensive in the long run.
Make sure you check the front axle oil as well.
Enjoy!
John
2014 PJ 24+6 T/A GOOSENECK (A50854)
2014 PJ 24+6 T/A...
IF YOU BID ON AN ITEM YOU MUST PAY FOR IT!! NO BACKING OUT AFTER IT IS SOLD!! (A50775)
IF YOU BID ON AN...
CATERPILLAR 259D3 SKID STEER (A50458)
CATERPILLAR 259D3...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2003 Big Tex 10PI...
2017 Rogator RG1300B Dry Fertilizer Applicator (A51039)
2017 Rogator...
KLEIN TOOLBOX (A50854)
