Bought a rear set of hydraulic forks.
   / Bought a rear set of hydraulic forks. #1
JimR
Elite Member
Central Ma.
Kioti NX4510HST
Not sure who converted this but after putting on new hoses it works great. The forks are Claw Grab style where you can pinch in or push out on anything, The maximum width is 6 feet. The lift I believe is 11 feet when resting on the ground. I'll have to measure it. The whole unit angles in and out at the top. This unit came off of a fork truck and converted to 3pth. I bought it for lifting my deck to replace the 12 foot posts and to do tree trim work using an IBC tote strapped on the back.
   / Bought a rear set of hydraulic forks. #2
Super looking setup! You scored well in that purchase.
...handy as a shirt pocket.
Thanks, I can't wait to try it out with a basket on the back.
   / Bought a rear set of hydraulic forks. #4
Nice setup, the hydraulic adjust on the forks would be handy.
Have to be aware that it is possible to overload the 3 pt hydraulics,
I have had mine start a hiccup with them drifting down and the tractor trying to raise them to the point of lifting the pressure relief.
removing weights 4.jpg removing weights 2.jpg IMG_20171013_105601463.jpg View attachment IMG_20180111_112610294.jpg
Using the forks to handle 300# wheel weights and carrying a one ton pallet of coal.
They did balk at lifting 3600# mafia blocks at the end of the forks :thumbdown:
they would carry one at a time when I backed under them and got them pushed all the way on to the uprights.
View attachment 663557 View attachment 663558 View attachment 663559 View attachment 663560
Your forks appear to be a much bigger setup than mine and much closer to the tractor. I also have front forks for my quick attach setup.
   / Bought a rear set of hydraulic forks. #6
Can see where that will be very handy. I might need a camera.
   / Bought a rear set of hydraulic forks. #7
Those are nice - a whole new meaning to rear-forks. Just looking at your pictures I can think of a million ways to use them.
gg
I know that I can't lift that kind of weight with my 3pth. But it would be nice to. Now I am wondering if my tractor could carry an IBC tote full of wood on the back forks while I have one on the front forks.
Those are nice - a whole new meaning to rear-forks. Just looking at your pictures I can think of a million ways to use them QUOTE]
I have been thinking of a lot of was ways that these can be used. Lifting shingles up to the roof, doing siding, powerwashing the house. You could make a 10 foot wide or bigger work platform that the forks could go thru and clamp into place.
   / Bought a rear set of hydraulic forks. #10
Those extensions are a little scary. I wouldn't put much weight on them, one looks bent already.
2012 PROCO 130BBL VAC TRAILER (A58214)
2012 PROCO 130BBL...
2014 Jeep Cherokee Sport SUV (A56859)
2014 Jeep Cherokee...
Bush Hog Rotary Cutter Mower Attachment (A56857)
Bush Hog Rotary...
2019 CATERPILLAR  XQ35 GENERATOR (A58214)
2019 CATERPILLAR...
2020 Global R3 Air Street Sweeper (A56857)
2020 Global R3 Air...
JOHN DEERE 348 SQUARE BALER (A58216)
JOHN DEERE 348...
