Bought a new box blade
/ Bought a new box blade #1
blucoondawg
Pelican Lake, WI
Kioti DK50SE w/ loader and Woods 90x backhoe, Allis Chalmers C with front snowplow
Well I pulled the trigger on a new box blade Friday afternoon, however I think the dealer made a mistake or intentionally screwed me over. The blade I bought was supposed to be a Woods BSM 72, I was in there about a month ago and was quoted a price of $1300 for that blade, I was told they keep that model in stock in the 72 and 84 size and could come back and purchase it whenever I liked. Well Friday I went down and bought the blade for a project I have at my mother's house. I told the salesman I want to buy one of your 72 inch BB's out front, he asked had I talked to anyone yet, I said a month ago I got prices on the 72 and 84 of 1300 and 1500, he sat at his desk and looked at pricing and said yes that is the correct price and proceeded to fill out the paperwork and sell me the blade. The mechanic loaded it on my trailer and away I went.
I got home after business hours and unloaded the blade, this is where the trouble started, the blade I was sold is not the BSM it is the BSS. I don't know if this is an honest mistake on their part like someone ordered in the wrong merchandise or if this is an intentional screw job, however honest mistake or not, that salesman should have known I was quoted a price for the BSM and not the BSS at 1300 dollars and either informed me they had the lighter weight blade and adjusted the price accordingly or told me I would have to wait for them to get the BSM in stock, either way I am mad as a wet hornet right now!!! I had planned to get this yard graded out and the driveway repaired over this weekend and now I cannot as I don't want to use this blade as I plan to see to it they take it back and get the proper one. At a minimum they are going to refund me the price difference between the models and I will sell it and buy the proper blade from a different vendor.
They also have these blades advertised on Tractorhouse and Fastline as BSM72's when if you click through the pictures of them you can see they are actually BSS, too bad I didn't see that before I made the purchase.
/ Bought a new box blade #2
Your first mistake was not being specific enough when calling out the model you wanted to buy. Since you did not use it simply return it for a refund or swap for the proper model of your choice. Try to be pleasant but firm, try to give them the chance to make it right, if that doesn't work then get a refund and go else where.
I can tell you this much, I do all of my research on equipment before I approach a sellers business. I can hand the dealer a note with the specific model or part number in most cases with the options I want as noted. Saves a lot of grief and time. I can compare his price with others in an apples to apples comparison.
Good luck with it.
/ Bought a new box blade #3
Good luck with it.
I second that
That is what I did when I got pricing a month ago, I went in there with a list of model numbers I was interested in, the standard duty blade was not on the list, I got the price quote for the correct blade and was told that is the blade they keep in stock. So when I went in to buy I had no reason to think I was getting something different. Also the 84 inch model they have IS a BSM. I have no idea why they have BSS in the 72 nor why they are advertising them online on 3 websites, one being their own corporate website, as BSM not BSS. That salesman should have known when I told him the quote I previously received that I was not quoted for the light duty model.
Seems to me he saw an opportunity to make a few hundred extra on something and took it, hoping I wouldn't notice the difference. If I wanted a 500lb class box blade I could have went to Fleet Farm and bought 2 King Cutters and still had a hundred bucks left over from what I paid for this blade.
/ Bought a new box blade #5
Sorry to hear about the mix up & hope you get it straightened out without losing respect for the dealer.
Once it's gone, it's gone, and a good dealer is a terrible thing to waste. Give him a chance to make it right.
When my dealer gives me a price quote, he takes the time to do it in writing.
He writes down the exact model number, unit price, tax, etc.
Because he does this, I can show up with a check and my copy of the quote and leave with the item, even if he's not there, and there's no misunderstandings.
After you get things straightened out, I look forward to seeing some pictures of your new BSM and the results of using it!
The guy I got the quote from wrote it in his notebook along with my name, he was not in when I made the purchase. That shouldn't really matter, I was not quoted any special reduced pricing, that price was the normal rate for the quoted item, I was sold a lesser item at the same price. I will get it straightened out on Tuesday and if they are not willing to admit the mistake then I will never do business there again and I will know I was intentionally screwed over.
/ Bought a new box blade #7
A month ago is a long time in a business, you should have again called out the specific model you wanted to buy when you came in last week. If it were me I would have walked out there and made sure the box blade on the lot was what I wanted to buy and pointed to it. Sorry you had this problem but that was your mistake. Did you get paper work on this blade and what was the description on it? If you drove home with the box blade before you knew it was the wrong one that tells me you didn't look at it before you left to verify it was the proper model you intended to buy.
I have made and continue to make a lot of mistakes. I have learned it is better to admit them as it is cheaper in the long run. I try not to repeat the same mistakes but it has happened.
/ Bought a new box blade #8
Print out a copy of their ad showing the BSM 72 and that is what you were quoted on a month ago and take it with you. Mention they made a mistake and gave you a BSS instead of the BSM.
No I did not, I saw the BSM 84 laying in the pile with the 72s behind it the 84 was a BSM as I was told, I was assured that those 2 sizes of BSM are the only box blades they stock as it is the only ones they sell because nobody is willing to pay the extremely high prices of the heavy duty Gannons in the area. I am willing to take responsibility for not checking it out closer and assuming this is an honest dealership, however would you mind explaining to me how it is my mistake that they are advertising on 3 or possibly more websites a BSM blade when they are actually BSS, and how it is my fault that a salesman was dishonest enough to sell at lesser item at the higher price?
When I am quoted a price and given info from a dealer I have done business with in the past (on smaller purchases and parts) I don't feel the need to triple check everything, if they are in business they should be honest about how they do business or they will lose business. These blades are the same blades that were there a month ago, laying in the same place blocked in by the same other equipment around them, I had no reason to believe they were different from what I was told they normally stock. I do not believe the price for the light duty blade went up to 1300 dollars in the past 3 or 4 weeks.
Ya that is what I am going to do, I have all 3 sites printed out however they don't have the price on the sites just "call for price". But I am going to call and talk to the salesman I talked to a month ago who wrote down my info and verify the price with him then ask why I was sold a lighter duty blade on Friday for that price.
/ Bought a new box blade #11
Everybody makes mistakes, the guy who sold it to you is not the one who picked it out of the inventory and loaded it on your truck. I bought a 48" set of pallet forks and noticed they were loading a set of 42" on my truck, I pointed it out and got the right ones. I always check to make sure I got what I wanted before bringing it home. I've made enough honest mistakes not to get too excited when someone else does.
Ya a mistake is a mistake, but in this case there are no other blades in stock to pick from for some reason both the new 72s they had were BSS not the BSM I was told they carry and they advertise online. Also the model number written on the receipt is BSS, not BSM so they knew what they were giving me. However the part number assigned by the dealership is the same as the "BSM" advertised incorrectly on the internet. Someone has some wires crossed somewhere. Hopefully it is a mistake and they correct it but I am still mad as **** about it because now I will be another week out on getting this project done at a minimum, and the fact that I have very little trust for dealers of vehicles or any kind of equipment tends to make me assume the worst rather than a honest mistake scenario.
/ Bought a new box blade #13
. I told the salesman I want to buy one of your 72 inch BB's out front, he asked had I talked to anyone yet, I said a month ago I got prices on the 72 and 84 of 1300 and 1500, he sat at his desk and looked at pricing and said yes that is the correct price and proceeded to fill out the paperwork and sell me the blade. The mechanic loaded it on my trailer and away I went. .
I am not saying that the dealer did not take advantage of you. But you made some mistakes too, you didn't specify to the salesman the model you intended to buy. You said you wanted to buy one of the 72" box blades out front. You are now saying that all they had out front was the BSS 72".
Overall I would not want to pay more for a purchase than it is worth. I already pointed out in my first post what I would do to correct the [problem. I am only adding this post because you say you are mad as a hornet. You need to recognize your mistakes in this transaction to prevent this from happening again.
Default Re: Bought a new box blade
/ Bought a new box blade #14
Hopefully you will get it straightened out, but that doesn't help you this weekend, so I can sure understand your frustration.
/ Bought a new box blade #15
Also, the BSS72 has a big sticker right on the back of it that says "BSS72". He clearly didn't even look at the unit after it was loaded on his trailer.
bluecoondawg: If you had gone in there to buy the BSS72 and paid the lower price for that one, and they accidentally loaded a BSM72 on your trailer and you took it home, should the dealer assume you were trying to cheat them?
My point is that this may just be, and probably is, an honest mistake. If you go in there all p!ssed off and accuse them of dishonesty, they may refund your money and tell you not to ever darken their doorway again. I'm an honest guy who has made a mistake or two in my life, and and that's what I'd tell you.
I know you're disappointed that you couldn't use it this weekend, but there's clearly some fault on your part here too. Just remember that you catch more flies with honey than vinegar.
/ Bought a new box blade #16
Sorry that happened to you. I agree with Pappy that you shouldn't go in accusing anyone of dishonesty. I think it was most likely an honest mistake, but I also think you're entitled to be upset, and I'd certainly let the dealer know that you are when you haul the blade back to them. Hopefully you aren't very far from the dealership.
Could you have caught the screw-up before you left with the blade? Sure, but of the two of you, the salesman is the pro and was in a much better position to catch it well before it was loaded on your trailer. Maybe he was new on the job, or distracted that day. The discrepancy in the quoted price of $1300 vs. what the BSS72 typically sells for should have been enough for him to know that either the prior salesman or you, the customer, had something else in mind.
Yes to the previous comments that we should always examine the paperwork, and look to see what the yard crew is actually loading on the truck or trailer (they'll usually double-check against the paperwork, and in your case, it said BSS72). I have a BSM84, and it is much more robust than the BSS84. But from 25 or 30 ft away, one could easily be mistaken for the other by a customer not used to seeing them side by side. Hope you can get this sorted out and put your BSM72 to work. I think you'll love it. :thumbsup:
/ Bought a new box blade #17
I agree that the op made some mistakes, but when he said that he was quoted $1300 for a 72" box blade they should have assumed which one it was.
It makes me wonder if they don't even realize what they have in the yard. Maybe they were shipped the wrong ones and it has slipped by everyone up to this point. The model numbers are so close that unless you were familiar with woods products it would be easy to get mixed up. The fact that your receipt shows bss on it, that maybe they were even sent the correct paperwork and it was put into inventory correctly, but their initial order called for bsm so the the sales guys are selling the bsm bevause that is what they ordered, but they came as bss. Sounds like bad communication between the sales people, the receiving people, and the people loading you trailer. I really wouldn't think they would be deliberately trying to sell a bss for $1300. And it further does not make sense that they would normally stock bss72 and bsm84... especially if they are priced within $200.
This is my reasoning exactly, and to the rest of you, I obviously have no intention of going in there and accusing anyone of anything unless they are going to be jerks about it and refuse to either refund me the difference I overpaid or replace the unit with the correct unit. Even if they don't replace the unit but refund me the difference in cost it at least gives me the option of selling the BSS for close to what I paid and then purchasing a BSM and not being out much or any cash. I simply don't want the lighter blade even though it is still a well built unit, it is still heavier than the blades sold at big box stores, it just isn't that much better to justify the price increase in my opinion and it is "rated" for up to 45 hp and I have 50hp, however the price increase to the BSM is acceptable for me because not only is it higher quality but also heavier which is the real reason for my wanting that one.
I just went out and loaded the blade back onto my trailer and also noticed the dealer has a plastic cable tie type tag on their equipment with the dealer name and dealer part number on it, this tag also has BSM 72 written on the back in pencil. So they apparently didn't even know what they had when they tagged it.
2025 48in. Farm Jack (A61567)
2025 48in. Farm...
207275 (A52708)
207275 (A52708)
2022 Case 5550 Trident Spreader LOW HOUR (A63118)
2022 Case 5550...
Zero Turn Mower (A59231)
Zero Turn Mower...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
UNUSED WOLVERINE TR-26-01C 3PT QUICK HITCH (A62131)
UNUSED WOLVERINE...
