Bota L4310 HST
   / Bota L4310 HST #1
jamtuc
Kentucky
John Deere 3720
I have been out for a while, I am looking at a tractor and need advice. 1999 L4310 HST with factory cab and front end loader. It has 3087.2 hours. Anything in particular I need to check? I know I will probably need tires on the front. Anywho, I always have always depended on you guys for the straight answer. Thanks in advance.
Jamie
   / Bota L4310 HST #2
L4310 is one of Kubota's first 'Grand L' models. Heavier than most of its competitors of the same size. Very reliable machine if it has been serviced regularly and operated prudently.
If it is a one owner machine that would be a plus.
If it has been inside stored that would be another plus.
L4310 was sold with 2-WD as well as 4-WD. Find out what this tractor has.
LINK TO TRACTORDATA.COM: TractorData.com Kubota L431� tractor information
   / Bota L4310 HST #3
Good tractor, if still in good shape. Nothing particularly problematic about the Lxx10 series, but, considering the number of hours and assuming the engine and drivetrain are good, I would also really look at front axle condition, the hydraulics, pto and the A/C since those would be the most expensive fixes.
   / Bota L4310 HST
Thanks guys, I knew I could count on you. It is 4x4, current owner says he has had the dealership do the maintenance.
2014 Freightliner M2 106 5.1Yds Asphalt Pot Hole Patcher Truck (A56858)
2014 Freightliner...
2017 CATERPILLAR 259D SKID STEER (A52709)
2017 CATERPILLAR...
2013 FREIGHTLINER CASCADIA (A58214)
2013 FREIGHTLINER...
Zero Turn Mower (A55853)
Zero Turn Mower...
2011 GMC Sierra 1500 (A56858)
2011 GMC Sierra...
2005 GMC C7500 24FT BOX TRUCK (A58017)
2005 GMC C7500...
