bora wheel spacer (3inch) L3200
   / bora wheel spacer (3inch) L3200
Thanks guys !
I have learned quite a bit about hubs and spacers.
I also realized today that the dealer installed my wheel spacer kit. I paid 250.00 they said it costs 350.00.
I never received the original hardware.
Mikes1165 pictures were perfect!!
The dealer now wants me to buy the hardware (2studs and lugs) for my tractor.
I bought a new tractor and a new kit should I have to pay again?
R3
   / bora wheel spacer (3inch) L3200 #12
I wouldn't think so. You've already paid for it.
   / bora wheel spacer (3inch) L3200 #13
I installed a set of Bora 3.5" spacers on my L3901 and have about 60 hours on them without any problems. Tractor is much more stable. I jacked the tractor up, put a strap around the tire and held it up with a cherry picker loosened the wheel and pulled it back. Removed the two studs and mounted the spacer with the included bolts, torqued bolts, remounted the tire to spacer and torqued lug bolts. Retorqued everything after 5 hours. Not hard to install just be careful because rear tires are heavy, especially if filled. Smaller headed bolts hold spacer to hub and tire lug bolts are like original lug bolts except a little longer as best I remember.
It's been a while now since the installation of the spacers. Are you still having no issues? How many hours now? Any words of wisdom after having used them for a while? Thanks.
   / bora wheel spacer (3inch) L3200 #14
My 6" spaces on a l3800
:devilish:
   / bora wheel spacer (3inch) L3200 #15
I installed Bora 2” steel spacers on my B2601. They’re fantastic and easy to install. I highly recommend them.
Mike
   / bora wheel spacer (3inch) L3200 #17
Did you try spacers on your L2501?
Not yet. The L2501 is pretty stable on my hillsides (with tire ballast).
However, if I move forward with spacers sometime in the future, I’ll likely go with 3”.
Mike
   / bora wheel spacer (3inch) L3200 #18
2015 L3301 here with at least 400 hrs on a set of 3” spacers and loaded R1 ag tires adjusted out to widest setting.
No issues to install, never had any issues of loosening, oil leaks, bent anything.
It was a game changer on my side of a hill property in Oklahoma.
Absolutely would do it again.
   / bora wheel spacer (3inch) L3200 #19
I have the same issue. I have an l3200 and ice chains, but there isnt enough room inside to install them. What size spacers have you guys used for this? I was thinking 3 inch. Thanks
UNUSED PALADIN SKID STEER HYDRAULIC BREAKING HAMMER (A51243)
UNUSED PALADIN...
John Deere 2155 Tractor (A51573)
John Deere 2155...
2014 INTERNATIONAL DURASTAR 4400 SERVICE TRUCK (A51406)
2014 INTERNATIONAL...
2019 Fontaine EQ1 Hydraulic Equalizing Spreader (A52377)
2019 Fontaine EQ1...
CATALOG UPDATES LOT NUMBER 5 (A53084)
CATALOG UPDATES...
10ft x 8ft Container with Side Door (A51573)
10ft x 8ft...
