Boosting FEL by Adjusting Relief Valve
   / Boosting FEL by Adjusting Relief Valve #11
<blockquote><font size=1>In reply to:</font><hr>
3. Marketing reasons. As with many other products--eg, car engines, computers--the manufacturer sometimes "detunes" some functional widget in the product (ie, makes it run less powerfully than it can), just so the manufacturer can charge more for the widget when it is incorporated into a higher priced model. That's how product differentiation is sometimes created. For example, I believe one of Deere's loaders has a higher lift capacity on one tractor than another.
<hr></blockquote>
This should probably be expanded on a little since it could lead to tragedy if not thought through. It is true that you can find cases where the same engine is used across a series of trucks or tractors and is detuned or intentionally restricted. However, it isn't quite as easy as claiming it to be strictly a marketing issue. Often times there will be lesser grade components attached to the engine. For example, you might find the same engine in a two trucks. Truck F350 is rated at 280hp while truck F250 is rated at 230hp. Same engine, different programming. However, the transmissions are likely to be different, as might the drive shaft, torque converter, rear end. Changing the programming might generate more power at the expense of wearing the transmission or breaking a drive shaft.
You should take care with the tractor parts as well. Yes, it might be the case that for economy during manufacture, they share some of the same parts. Don't mistake that, however, for sharing capabilities. The engineers who designed the rest of the tractor may be depending on the maximum rated loads of the detuned part.
As a general rule of thumb, if something is less expensive than another, then the manufacturer has done something to reduce the cost. Something is missing, lighter, smaller, thinner, or less reliable. You should take care whenever you reverse an engineers decisions. They knew more about the design than you did.
Kevin
   / Boosting FEL by Adjusting Relief Valve #12
As the owner of a 2710 and having done said deed (to the tune of about 2300psi) I can tell you that the loader is amazing after the adjustment! I originally did the adjustment because I was using a 3pt log splitter and did not like the performance at 1900 and some odd psi. So I adjusted it to approximatly 2300psi(I have a gauge). I can tell you that there is toooo much lift on the loader now however. I can lift the back tires with a box scraper loaded down with logs, tires, kitchen sink, me! It is definatly not safe with that much lift on a relativly lite tractor! Makes it very unstable. But it is impressive and doesn't seem to bother anything. Just the same I am going to lower it a bit.
2016 JOHN DEERE 700K LGP CRAWLER DOZER (A52705)
2016 JOHN DEERE...
Ford F250 Pickup Truck (A51694)
Ford F250 Pickup...
Willmar 4500 Wrangler Articulating Loader (A55314)
Willmar 4500...
2004 AGCO Gleaner 3000 Corn Header (A57024)
2004 AGCO Gleaner...
FORK ATTACHMENT FOR SKID STEER (A55745)
FORK ATTACHMENT...
