LD1
Epic Contributor
Sounds like you have cylinder seals blown out or a broken rod. Just fixed the same issue with a 310j backhoe, Running both sides of the hydraulics will increase flow in the system and overpower the fault momentarily. The best way to test is to set the rods at mid travel, hold them up with heavy jacks/another machine, tree stumps, etc (any way you can do it safely). cap the lines to the cylinders and remove whatever is holding it. You will get some initial drop of a couple inches from introducing some air into the system but it should hold stead after that initial drop. If it falls completely you will need to have the cylinders re-packed at a minimum.
Bad advise, and incorrect information for testing loader seals.
It looks like some of you guys know your hydraulic a lot better than I do. To quickly address some of the questions, it has 129 hours on the tractor. The loader was purchased with the tractor when new and is the special red 250TL that was painted red and stickered to match the tractor. I don't think it was used or anything like that. It is an 09 but I bought it from a dealer 3 years ago with 12 hours and that had to be the last one anywhere that hadn't sold. I hadn't used the lift too hard until I had a hole dug for a basement pour that made a huge pile of clay that needed moved after they were done. Until a couple weeks ago when I replaced the leaking hose, I had never disconnected the quick connects and last night was the first time I have ever removed the loader from the tractor. Pressure gauge finally came in and I went to tractor supply and picked up some fittings to get some readings. 2500 PSI at all quick connectors when circuit was activated. So I probably didn't have it set up correctly because next I put a "T" fitting on for checking pressure along the different points. As soon as I put a T in the line, the pressure reads about 300-400 psi. This is the first clue on what is going on. Anyways, After messing around with it and "checking pressure" at several points, I took off the line and put the gauge on the end of the hose supplying the right cylinder (I was curious if hydraulic hoses swell up and pinch off supply like a rubber brake line does) like and so the gauge terminated the lift line (plugged it off) so I could get a pressure reading. I guess they don't but I was stumped and looking at everything I could think of. When I started it up that time, I pulled back on the joystick and the loader lifted up (with great surprise I might add) with just the left side cylinder connected. Anyways, I pulled the loader off to get to the cylinder attachment points and removed that lift cylinder. There is something inside rattling around so I am guessing that something let loose and that is where the problem lies. I don't have another day off until next week so I'm taking the cylinder to the New Holland dealer and they are going to check it out for me. So, discussing it with a friend, why would it still lift when you had it curled all the way back and the best guess and our conclusion is: no clue, but maybe since both are draining, it caused some pressure to build up allowing the other cylinder to do the lifting. Pure speculation. But I now know that there is a problem in the right lift cylinder and things make a little more sense.
Late to the thread, but it sounds like you have a broken piston, or at least a nut that has fallen off the bottom of the piston that holds that rod on.
Why your curl was having an influence on the loader lift....yea thats odd.
Waiting to see what you find inside that cylinder.
