cougarmandan
So, for the first time in its life, my 2009 New Holland Boomer 8N is having to earn its keep. I am doing some dirt work at my house with some hard clay dirt. Its been acting strange lately. It has 121 hours so far. The 3 point hydraulics work great, not problem there. However, the 250TL loader is having some major hydraulics issues. It started out if you pointed the bucket down and drag it back to spread the dirt, it wouldn't hold the bucket position at all, then it wouldn't lift the bucket at all and would fall straight down if you tried to lift it. If you let the bucket all the way down, it could then be lifted back up. Unrelated, one of the hoses started oozing out of a small crack so I replaced it on the bucket lift but I don't think it is related. Well, progress to "we" kept using it and it has gotten worse. Now, there is almost no lifting the bucket and there is only one way to lift it. if you curl the bucket all the way back while simultaneously lift, it will go up, but its weak. I call it the bucket curl where the bucket hinges on the end. The curl is strong. It will lift the tractor up. Oddly, if you have it curled all the way up, it will lift the bucket up. If you get it up, and stop curling while still lifting up, it will fall down, fast (and very dangerously). I pulled the control valve assembly and carefully disassembled it. I cleaned and cleaned it and put it back together. It doesn't appear to have much wear or filth on it. Other than greasing up the float detents which allow it go into float now, it hasn't changed a thing. I talked to the local dealer who I would say was very helpful and the technician had a little trouble grasping what I was saying, but said I need to get pressure readings on each of the quick connector ports. I have a gauge ordered and in route but it won't be here until next week. Anyways, he said to check the relief valve for a broken spring and make sure all my couplers are seated. I took the couplers off and reseated them. The relief valve is part of the diverter assembly so I took out the plug and cleaned the spring and valve. I did notice what I thought was a chunk of oring or black paint in the female quick coupler, I got it out but it didn't seem to help. Anyone had a similar issue? My thoughts were pull the coupler and make sure there is nothing on the back side (if you can see it) and maybe pull the diverter all the way out (which will be a pain) and see if I can locate any trash inside it. Also, I changed the hydraulic filters yesterday and there is plenty of fluid.
