Boomer 55 no start
   / Boomer 55 no start #1
droy
Southwest Louisiana
NH Boomer 55, ZD1211
Boomer 55 hydrostatic with 156 hours (cab & fel)
Wife used tractor to pull out stuck zero turn, parked it. 30 minutes later it made a single click noise when I attempted to start it, then nothing. No power to dash, or relay box & fuse box near steering column. I didn’t check other in cab fuse box but probably dead also. Battery measures 12.7 volts, the 120 amp fuse on positive clamp has voltage on both sides. Is there another in-line fuse before the cab? Operator manual not much help so hoping one of you guys could point me in the right direction.
Thanks in advance!
Add to my previous post / problem I did also find two fuses 1-30 amp, 1-40 which manual states the 40 amp is ECU fuse mounted top back side of air filter along side two relays (guessing relays are for glow plugs or intake heat). Both fuses check good.
Also while checking my 71 yo “not what they used to be” ears detected a slight buzzing sound still under hood but closer to the firewall. Disconnected battery for about an hour hoping for a reboot (miracle) but no change after reconnecting buzzing sound also returned.
   / Boomer 55 no start #3
Jump your battery. When the tractor starts, check voltage at battery, should be 14+/_VDC.
Replace battery with new one.
My tractor did the exact same thing, including the strange buzzing. Relays and transistors get weird with low voltages.
Patrick
   / Boomer 55 no start #4
1st check would be battery post/terminals are clean and there is a good ground connection to the negative lead.
   / Boomer 55 no start #5
Put meter on battery than try to start while watching meter. Ill bet it really drops.
Like posted earlier, a charged battery reads somewheres between 13.5-14.2 vdc.
Also, grip connections at battery and twist. If they move at all, clean and retighten till they dont twist. Also, make sure points where cables attach to starter and body ground are clean and tight.
2017 Buick Regal Sedan (A50324)
2017 Buick Regal...
2008 STEPHENS 220BBL CRUDE OIL TRAILER (A50854)
2008 STEPHENS...
(2) METAL SPOOLS W/ SOME DURALINE 4" PVC PIPE (A51244)
(2) METAL SPOOLS...
2014 Ford Explorer SUV (A50324)
2014 Ford Explorer...
71059 (A49346)
71059 (A49346)
2016 Nissan Pathfinder SUV (A50324)
2016 Nissan...
