BOOMER 50 Frustration with the owner's manual.
   / BOOMER 50 Frustration with the owner's manual. #1
Calgaryglenn
Innisfail Alberta
IHC 584 Jd 450C JD 350C Ford 1220, Kubota 900X, NH Boomer 50 and all kinds of attachments
I am getting my tractor ready for winter and I changed the front differential gear oil. The owner's manual says the capacity of the diff is 8.1 liters. So I buy a 10-liter jug of full synthetic Shell 75W140 gear oil for close to $220 and when I drain and refill only 5.5 liters go in. I measured what came out and it's 5.5 liters! There are only 3 drain plugs: one on each final drive and one on the bottom of the diff housing so I didn't miss one. Now I am stuck with some very expensive oil I don't need.
How could they print such erroneous information in the owner's manual?
   / BOOMER 50 Frustration with the owner's manual. #2
I don't know, and that's frustrating for sure, but don't most NHs use hydro oil in the gear cases? Oops, I guess not. Just checked my workmaster 40 owners manual. Mine calls for hyploid 90. The old TC26DA called for the hydro oil.
   / BOOMER 50 Frustration with the owner's manual. #3
Hey, it will be there when you do your next oil change!
I know but it still rubs me because I will have to buy another jug to finish the job since I will be short....I know I know....first world problem.
Case 1494 Loader MFWD Tractor (A49339)
Case 1494 Loader...
2018 Dodge Charger Sedan (A46684)
2018 Dodge Charger...
2018 KENWORTH T680 TANDEM AXLE SLEEPER (A45678)
2018 KENWORTH T680...
84in Fork Extensions (A49346)
84in Fork...
2022 Ford Take-Off Bed (A49251)
2022 Ford Take-Off...
6ft. Wallace Box Blade (A49339)
6ft. Wallace Box...
