Boomer 50 Down
   / Boomer 50 Down #1
catloader988
Medina OH
New Holland Boomer 50
Hello, I recently bought a brand new 2013 Boomer 50 with all the bells and whistles. I used it a handful of times to clear snow from my driveway and cut 7 acres of grass twice. Today I had gravel delivered to the house to top my driveway. I worked the tractor pushing stone around for about 2 hrs, then the machine started acting goofy. Surging and stalling. I got it back to the barn and it died again, this time the oil pressure light came on, cranked and fired a couple times running for about a minute each time now .the machine wont start, wont even crank over. I checked all the fluids and changed the oil filter hoping maybe it was clogged. Nothing, still the same dead worthless machine. I am furious considering the tractor has 30hrs and i paid so much for it. It does have a warranty but ill have to eat the cost to get the machine moved up to the dealership. Has anyone else had the same issue with their Boomer series?
   / Boomer 50 Down #2
Sounds like bad alternator or electrical issue to me. Reason I say this is that it should at least turn over. Sorry to hear about your troubles.
   / Boomer 50 Down #3
Changed the oil filter?? I hope you mean changed the fuel filter for those symptoms.
The oil pressure light will come on because you said the engine died, and thus the if engine stopped turning the oil pump did too, so the pressure went down and turned the light on.
You are going to have to give more details on what you were doing and what happened when it stopped. It really sounds like a fuel problem. Did you get bad fuel? Didn't winterized it and it solidified? Water in the fuel filter? Have you checked the fuel filter bowl to see what it looks like?
It sounds to me like you have a fuel delivery issue and then kept cranking it to attempt to restart it until the battery died, and now it won't even turn over.
Charge the battery and look at the fuel filter bowl and report back.
   / Boomer 50 Down #4
I'd check on that, my dealer sends a field service truck for free during the warranty period. And if they need to bring it into the shop they pick it up for free.
Do a few simple things first. I'd look at the bottom of the fuel filter bowl with a flashlight for contamination or water. If it's hard to see, pull the bowl and check it. Crack the valve while the bowl's off to make sure fuel flows freely from the tank. Make sure the vent in the fuel tank cap isn't plugged. I'd also pop the air filter and make sure some rodent didn't make a nest in there while you weren't looking. Don't use the starter for long periods of time while you're diagnosing, don't want to damage it.
   / Boomer 50 Down
Battery is still at 12v. Starter shows 12v at terminals. I don't think it's a fuel issue, but I'll throw one on if I can get it cross referenced. Seems like a sensor to me. Oil or safety switch not letting it crank now
   / Boomer 50 Down #6
I've not heard of oil pressure switch being in the starting circuit, don't see how that could work since you don't have any oil pressure until it starts. I'd jump the starter to make sure it cranks, make sure it's in neutral and brake on. If it does, check fuses then each of the usual safety culprits: PTO not engaged, HST neutral position, seat switch hasn't fallen off, etc. If there's nothing obvious, start jumpering switches one at a time.
   / Boomer 50 Down
It's just strange to me that when it did crank and run for minutes at a time that you had to wait a few minutes before it would attempt to crank again.
   / Boomer 50 Down #8
12V is a pretty dead battery. Does it click and chatter -- or not even try to turn. What V does it hold to when you turn the key?
larry
   / Boomer 50 Down
I pulled every fuse all good jumped the tractor battery with my truck nothing different. Tinkered with all the saftey devices hst pedal parking seat sensor pto switch. I'm so aggravated ill jump the starter solenoid this afternoon but I'm at a loss and getting farther away from my orginal problem. That happened when the tractor was already running.
   / Boomer 50 Down #10
There is a main disconnect right at the starter and if it is loose NO power goes to the tractor. It is a single white wire to the starter on my unit. Our local dealership uses it as a anti theft device and now I do too. Check the large white wire going into the starter and see if the male/female clip is properly attached.
2015 Ford Escape SUV (A50324)
2015 Ford Escape...
2012 Chevrolet Silverado 2500 HD Enclosed Service Truck (A52377)
2012 Chevrolet...
Starcraft Starlite 22ft Travel Trailer (A51694)
Starcraft Starlite...
New/Unused Quick Attach Auger with Three Bits (A51573)
New/Unused Quick...
2015 Peterbilt 579 T/A Sleeper Cab Truck Tractor (A52377)
2015 Peterbilt 579...
2007 FORD F-250- LARIAT 4X4 (INOPERABLE) (A52472)
2007 FORD F-250-...
