Boomer 40 flywheel torque value ?
/ Boomer 40 flywheel torque value ? #1
TRACNUN
I have a manual
SERVICE MANUAL
Boomer ™ 40
Boomer ™ 50
Tier 3
Compact Tractor
and nowhere does it show the engine flywheel or its 4 bolts, so no torque values either.
also, in the bell housing, the drive shaft cover that has three bolts, you have to remove to replace the seal and o ring, it shows you how to remove it, the manual does not have the reinstall section for that and the torque values
Thanks
not one reply
/ Boomer 40 flywheel torque value ? #3
Tracnun you can verify the diameter and grade of the bolts,then lookup on the web “bolt torque chart”. This has helped me when torque values are not listed in the manuals.
/ Boomer 40 flywheel torque value ? #4
Sorry my reply was for TC40, not a Boomer 40
thanks, i had those resources as well, i finally went 60 foot lbs, hope that will be ok, one post somewhere said 150 and i was like lol no way
2017 P.J. Deck Over Trailer, VIN # 4P5F82021H1265098 (A65563)
2017 P.J. Deck...
New 4400lb All Steel Adjustable Gantry Crane (A62679)
New 4400lb All...
2001 Blaw-Knox PF 150 Paving Machine  (A62679)
2001 Blaw-Knox PF...
2012 MACLTT  150 BBL ALUMINUM VACUUM TRAILER (A65643)
2012 MACLTT 150...
2016 INTERNATIONAL 4300  4X2 24FT BOX TRUCK (A67147)
2016 INTERNATIONAL...
Lonestar Panel 24ft. Free Standing Panel with 7ft. Gate (A65640)
Lonestar Panel...
