Boomer 30 parking brake light
   / Boomer 30 parking brake light #1
kupperpooh
chilton
New Holland Boomer 30
I have a new holland boomer 30 with the parking brake light on constantly. I have tested the switch and it is good. I have also tested the fuses and they are ok as well. Does anyone have a wiring diagram or any other ideas?
   / Boomer 30 parking brake light #2
If you manually press the brake switch with the key on does the light go out? I have an LS XR3037HC (similar to a Boomer 37) and had a similar problem. I had to adjust the switch to make the light go out when I released the handle.
Holding it in does not change a thing. I did test the switch and it is working.
2018 Taylor-Dunn BigFoot B5-440-36 Electric Utility Cart (A50324)
2018 Taylor-Dunn...
1995 Ford F-700 Flatbed Truck (A53117)
1995 Ford F-700...
2016 FONTAINE 53FT SPREAD AXLE DROP DECK FLATBED TRAILER (A53426)
2016 FONTAINE 53FT...
2008 DOOSAN G25 GENERATOR (A52472)
2008 DOOSAN G25...
UNUSED FUTURE SF60 HYD MAST W/ 60" FORKS (A51248)
UNUSED FUTURE SF60...
(INOP) FORD 7710 TRACTOR (A51247)
(INOP) FORD 7710...
