Boomer 30 parking brake light
   / Boomer 30 parking brake light #1
kupperpooh
chilton
New Holland Boomer 30
I have a new holland boomer 30 with the parking brake light on constantly. I have tested the switch and it is good. I have also tested the fuses and they are ok as well. Does anyone have a wiring diagram or any other ideas?
   / Boomer 30 parking brake light #2
If you manually press the brake switch with the key on does the light go out? I have an LS XR3037HC (similar to a Boomer 37) and had a similar problem. I had to adjust the switch to make the light go out when I released the handle.
Holding it in does not change a thing. I did test the switch and it is working.
2008 Ford F350 XL, Diesel Dump Bed w/Spreader Box (A52384)
2008 Ford F350 XL...
HOMEADE PIN ON 2 PRONG HAY SPEAR (A51247)
HOMEADE PIN ON 2...
CHAMPION 3" CHIPPER (A51248)
CHAMPION 3"...
UNUSED CFG INDUSTRIAL MX12RX EXCAVATOR (A51247)
UNUSED CFG...
2014 Club Car Electric Utility Cart (A51691)
2014 Club Car...
2007 Eager Beaver 35 GLB Lowboy, Tandem Axel (A52384)
2007 Eager Beaver...
